Surface Pro 4 battery percentage doesn't change while charging
2016-08-13T20:02:09+00:00
Since the Windows 10 anniversary update, my surface's battery percentage does not change when it is charging. When I unplug the charger, then it changes the battery percentage right away, but the percentage does not change when the charger is actually plugged in. When I hover over the battery icon, it only says how much time left until fully charged, but the time left does not change either. I would like to avoid leaving the surface charging when the battery is already fully charged, and I don't want to have to unplug the charger just to check. Please help.
    2017-10-25T01:19:30+00:00
    I have the same issue on 1703.
    This behavior started about 2 or 3 updates ago.
    Should not have to install 3rd party apps to check charge status!
    2017-07-01T19:00:46+00:00
    Check for Performance monitor to understand what application is consuming a lot of CPU and memory. To view the information. Follow the steps provided below:
    1**.** Type Reliability in Cortana. 2. Select Reliability history.
    It will generate the information that you needed, send us a screenshot for review.
    Regards.
    2017-06-27T08:01:57+00:00
    Good day, thanks for your advice. No NEC. And "roll back driver" is not available for click.
    I tried repair tool and nothing improve.
    Thanks.
