Surface Pro 4 battery percentage doesn't change while charging
2016-08-13T20:02:09+00:00
Since the Windows 10 anniversary update, my surface's battery percentage does not change when it is charging. When I unplug the charger, then it changes the battery percentage right away, but the percentage does not change when the charger is actually plugged in. When I hover over the battery icon, it only says how much time left until fully charged, but the time left does not change either. I would like to avoid leaving the surface charging when the battery is already fully charged, and I don't want to have to unplug the charger just to check. Please help.
    2017-01-05T00:51:22+00:00
    I'm experiencing the same issue. I updated all the drivers (uninstalled/deleted).
    I even exchanged my surface for a new one (i5 128 gb) and it still doesn't work.
    Please advise.
    Thank you
    2017-01-04T15:51:53+00:00
    I'm also having this issue. Recently bought SP4 i5 and everything is updated.
    2016-12-29T18:48:50+00:00
    Daniel,
    Thank you for your reply. It was done by the Microsoft support guy when i showed him your post. But that did not solved my problem. Eventually, I had to return it as even they recommended same. Finally, new one is working fine without any issue.
    Thank you again,
    Fayaz
    2016-12-29T16:55:14+00:00
    Fayaz,
    If you haven't returned the product, I suggest you try out the solutions given.
    I installed the updates mentioned above manually through the msi file. Then, to make double sure, I uninstalled both battery drivers (battery + adapter, being careful NOT to check a box that says delete files), and then restarting.
    I don't work for Microsoft, but returning a perfectly good product was not an option for me. Now I get different readings every few minutes while charging.
    Please let me know your progress.
    Daniel
    2016-12-29T16:41:58+00:00
    Hi Fayaz,
    Are there any available updates that you haven't installed yet?
    Regards.
