Surface Pro 4 Battery Indicator Issue
I too bought my Surface Pro 4 just a day before Christmas. I have noticed that, as long as the charger is connected, the battery indicator remains at the same value. If I disconnect, the indicator returns to the real battery percentage. While on battery, percentage goes down, unexpected.
Also I noticed the while keeping the pro on battery discharge, its is showing weird discharge indications. Such as at 90% it will show 2 hrs remaining and at 85% it will show 6 hrs remaining !!!
I found it annoying to have to plug out every time to know charging status of the machine. I did try help support, but they said me this is the way it works and it will update every 5 minutes (hilarious reply after being on calls for hours)!!!
Hope someone from Microsoft will help to figure out, else I have no choice to drop out as their valued customer and return this product.
Fayaz
