Hi Daniel,
Has the update been finished? Please follow these tips about how to install Surface and Windows updates.
Regards.
Since the Windows 10 anniversary update, my surface's battery percentage does not change when it is charging. When I unplug the charger, then it changes the battery percentage right away, but the percentage does not change when the charger is actually plugged in. When I hover over the battery icon, it only says how much time left until fully charged, but the time left does not change either. I would like to avoid leaving the surface charging when the battery is already fully charged, and I don't want to have to unplug the charger just to check. Please help.
Hi Daniel,
Regards.
It seems like I have the latest updates installed. Maybe
I can force an update? What are your thoughts?
I bought my Surface Pro 4 a few days ago. I have noticed that, as long as the charger is connected, the battery indicator remains at the same value. If I disconnect, the indicator returns to the real battery percentage. While on battery, percentage goes down, as expected.
As soon as I turned it on, the Surface started updating. I mention this because I have read other posts saying that it happened after the anniversary update. Do we have a solution to this problem? Thanks!
I'm still having this problem. Any luck?
