Surface Pro 4 battery percentage doesn't change while charging
2016-08-13T20:02:09+00:00
Since the Windows 10 anniversary update, my surface's battery percentage does not change when it is charging. When I unplug the charger, then it changes the battery percentage right away, but the percentage does not change when the charger is actually plugged in. When I hover over the battery icon, it only says how much time left until fully charged, but the time left does not change either. I would like to avoid leaving the surface charging when the battery is already fully charged, and I don't want to have to unplug the charger just to check. Please help.
    2016-11-20T17:54:19+00:00
    Same problem here. Hasn't been a solution found yet?
    2016-09-07T02:38:03+00:00
    Same with me.  Since the update, my battery charge status does not update on SP4 unless I unplug the power cord and then plug it back in.  Also, I cannot toggle the brightness on the screen.  Is there a fix coming??
    What version of windows 10 are u currently running?  Do a winver in a dos box to find out.  Pls post back the results.
    2016-08-30T20:30:23+00:00
    I've the same problem since anniversary update. Plus, I can't see recommended screen brightness anymore. I see a generic brightness button without the auto setting, a bit darker, darker, etc. (bottom right battery icon).
    2016-08-21T14:29:08+00:00
    Hi MoonK15,
    Thank you for reaching out. We are conducting a follow up regarding your concern. Was your issue being resolved? Is there any changes on the battery when you restart your Surface Pro 4 or when you reconfigured the battery settings on the device? We suggest that you check this link on how to troubleshoot battery issue. Let us know how it goes.
    2016-08-13T20:24:51+00:00
    I noticed that happening also after the anniversary 1607 update.  I had other more serious issues so I fully reinstalled the anniversary edition.  I am not sure when the battery status issue disappeared but I can tell u that I also installed the latest update for 1607 and the latest intel beta display driver because of other issues.  Most issues are resolved but I still may go back to the pre anniversary win10 since it had fewer problems and was better on battery.
