Fixed w/ KB5053656 3/27/2025.
G Pro X Wireless plays mute/unmute sound when audio starts or volume is changed
I'm having this issue since updating to Windows 11 24H2, I've talked to Logitech support and they said since this is only happening on my PC and not others, its a Windows 11 update issue.
Here is what they said:
I understand your concern. I request you to contact Windows support as you are facing the issue after the Windows 11 update. There are high chances of audio drivers not updated properly. Hence, if you contact Windows support they will help you reinstall the software.
Please advise on how I should proceed, I've also linked a Reddit post with people having the same issue:
https://www.reddit.com/r/LogitechG/comments/1fml5oz/g_pro_x_wireless_plays_muteunmute_sound_when/
No one has found a solution yet
regards,
Taimur Ansari
78 additional answers
2025-02-10T22:12:14+00:00 I just fixed it by disabling voice focus within the sound settings for this mic in windows.
2025-01-11T11:17:52+00:00 same problem on windows 11 pro 24H2. this is really annoying. I tried the last workaround showed here and still doesn't solve the issue. Please release a fix patch for this Microsoft
2024-10-27T02:24:14+00:00 Hi Taimur Ansari,
Thank you for getting back to us.
We are glad to hear that you found a workaround.
If even a clean Windows 11 24H2 installation has problems, it may mean that there are specific interaction problems/compatibility conflicts between the new driver API/system API and the hardware, such as passing an unexpected 2.4Ghz band wireless signal, or sending some electrical signal to the hardware to trigger the hardware's sound alarm.
However, due to the limitation that similar problems have not been observed on my personal device, it is difficult to provide an accurate conclusion.
Do you still have some wired devices?
Will this situation occur in a wired device? Or will it occur in other wireless devices or Bluetooth devices that are not based on a 2.4GHz LIGHTSPEED connection?
Best Regards,
Kyo.Y - MSFT | Microsoft Community Technical Support
2024-10-25T18:50:21+00:00 One of the workarounds mentioned in the thread worked for me - checking the 'Listen to this device' in additional sound settings(Microphone properties). I would still like a permanent fix, but no beeping for now at least!
What do you think could be causing this issue considering this workaround worked?
