G Pro X Wireless plays mute/unmute sound when audio starts or volume is changed
2024-10-24T20:33:55+00:00
I'm having this issue since updating to Windows 11 24H2, I've talked to Logitech support and they said since this is only happening on my PC and not others, its a Windows 11 update issue.
Here is what they said:
I understand your concern. I request you to contact Windows support as you are facing the issue after the Windows 11 update. There are high chances of audio drivers not updated properly. Hence, if you contact Windows support they will help you reinstall the software.
Please advise on how I should proceed, I've also linked a Reddit post with people having the same issue:
https://www.reddit.com/r/LogitechG/comments/1fml5oz/g_pro_x_wireless_plays_muteunmute_sound_when/
No one has found a solution yet
regards,
Taimur Ansari
2025-03-30T14:14:14+00:00
Fixed w/ KB5053656 3/27/2025.
78 additional answers
    2025-01-06T23:00:50+00:00
    I tried it as well, and it didn't work for me.
    2025-01-02T11:46:17+00:00
    Can you update on this topic as its been more than 1 month, and its still not fixed. The 24H2 is your mistake and it has more than one known issue. Are you solving those? What status this has??? where we can escalate this as we dont have any update for almost 2 months now!
    2024-12-31T16:03:40+00:00
    Because indian support doesnt know how to fix it. I dont want to be rude, but thats a fact - unfortunately. They develop and release something that hasn't been tested properly, thats how microsoft works last years.
    2024-12-13T19:08:58+00:00
    same here 24/h2 is the problem. 23was fine (at least in this regard)
