G Pro X Wireless plays mute/unmute sound when audio starts or volume is changed
2024-10-24T20:33:55+00:00
I'm having this issue since updating to Windows 11 24H2, I've talked to Logitech support and they said since this is only happening on my PC and not others, its a Windows 11 update issue.
Here is what they said:
I understand your concern. I request you to contact Windows support as you are facing the issue after the Windows 11 update. There are high chances of audio drivers not updated properly. Hence, if you contact Windows support they will help you reinstall the software.
Please advise on how I should proceed, I've also linked a Reddit post with people having the same issue:
https://www.reddit.com/r/LogitechG/comments/1fml5oz/g_pro_x_wireless_plays_muteunmute_sound_when/
No one has found a solution yet
regards,
Taimur Ansari
2025-03-30T14:14:14+00:00
Fixed w/ KB5053656 3/27/2025.
78 additional answers
    2025-04-11T09:40:50+00:00
    Yeah looks like it fixed guys!!!
  2. Deleted
