G Pro X Wireless plays mute/unmute sound when audio starts or volume is changed
2024-10-24T20:33:55+00:00
I'm having this issue since updating to Windows 11 24H2, I've talked to Logitech support and they said since this is only happening on my PC and not others, its a Windows 11 update issue.
Here is what they said:
I understand your concern. I request you to contact Windows support as you are facing the issue after the Windows 11 update. There are high chances of audio drivers not updated properly. Hence, if you contact Windows support they will help you reinstall the software.
Please advise on how I should proceed, I've also linked a Reddit post with people having the same issue:
https://www.reddit.com/r/LogitechG/comments/1fml5oz/g_pro_x_wireless_plays_muteunmute_sound_when/
No one has found a solution yet
regards,
Taimur Ansari
2025-03-30T14:14:14+00:00
Fixed w/ KB5053656 3/27/2025.
78 additional answers
    2024-12-18T12:47:21+00:00
    Same issue. The playback workaround worked for the first time but as I rebooted my pc, the problem continues.
    2024-12-18T11:21:41+00:00
    yea.. same its happen to me after i install new update.. when I'm not listening to song it will randomly started to pop that beeping sound.. its kinda sad
    2024-12-06T19:22:16+00:00
    I guess you didn'tunderstand the "playback" part, but I can get an L1 support to help you if you need.
    2024-10-31T20:33:40+00:00
    Hey Kyo,
    It looks like no one has replied, so you'll just have to rely on my input. Do you have any ideas on how to proceed, knowing this is a Windows 24H2 issue only? The Redditors at least feel that is the case anyway.
    regards,
    Taimur Ansari.
