2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-28T14:47:14+00:00
    I had my SP3 replaced under warranty when the battery would not charge.  Now, it won't stay on unless plugged in, but is likely out of warranty support.  I've seen wild fluctuations in the battery charge value shown in Windows - goes from 100 to 10% in seconds, plugged in and at 80% immediately.  The earlier comment about how difficult it will be to change the embedded software with the battery pack does not make me hopeful that this can be addressed.
    Last week, I had a bit under 800 mWH capacity, now it's under 50!  To coin a phrase, this is Simplo unacceptable.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=130ad4d3-37e1-4f28-bcc7-4f2f12fe8c61)
    2016-07-28T12:37:17+00:00
    My Surface Pro 3 is also facing the same issue. Looks like it started in May and degraded from there.
    Here is my log
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1167202820
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 2,379 mWh
    CYCLE COUNT 84
    Battery capacity history
    Charge capacity history of the system's batteries
    2015-11-23 - 2015-11-30 42,583 mWh 42,157 mWh
    2015-11-30 - 2015-12-07 42,583 mWh 42,157 mWh
    2015-12-07 - 2015-12-14 42,583 mWh 42,157 mWh
    2015-12-14 - 2015-12-21 42,583 mWh 42,157 mWh
    2015-12-21 - 2016-01-11 42,583 mWh 42,157 mWh
    2016-01-11 - 2016-01-21 42,583 mWh 42,157 mWh
    2016-01-21 - 2016-01-25 42,583 mWh 42,157 mWh
    2016-01-25 - 2016-02-01 42,583 mWh 42,157 mWh
    2016-02-01 - 2016-02-08 42,583 mWh 42,157 mWh
    2016-02-08 - 2016-02-15 42,583 mWh 42,157 mWh
    2016-02-15 - 2016-02-22 42,571 mWh 42,157 mWh
    2016-02-22 - 2016-02-29 42,576 mWh 42,157 mWh
    2016-02-29 - 2016-03-07 42,578 mWh 42,157 mWh
    2016-03-07 - 2016-03-21 42,583 mWh 42,157 mWh
    2016-03-21 - 2016-03-28 42,583 mWh 42,157 mWh
    2016-03-28 - 2016-04-04 42,583 mWh 42,157 mWh
    2016-04-04 - 2016-04-11 42,583 mWh 42,157 mWh
    2016-04-11 - 2016-04-18 42,583 mWh 42,157 mWh
    2016-04-18 - 2016-04-24 42,569 mWh 42,157 mWh
    2016-04-24 - 2016-05-02 42,562 mWh 42,157 mWh
    2016-05-02 - 2016-05-08 42,583 mWh 42,157 mWh
    2016-05-08 - 2016-05-16 41,652 mWh 42,157 mWh
    2016-05-16 - 2016-05-23 37,857 mWh 42,157 mWh
    2016-05-23 - 2016-05-31 33,783 mWh 42,157 mWh
    2016-05-31 - 2016-06-07 27,631 mWh 42,157 mWh
    2016-06-07 - 2016-06-14 22,912 mWh 42,157 mWh
    2016-06-14 - 2016-06-21 18,736 mWh 42,157 mWh
    2016-06-21 - 2016-06-28 15,333 mWh 42,157 mWh
    2016-06-28 - 2016-07-05 11,360 mWh 42,157 mWh
    2016-07-05 - 2016-07-12 8,053 mWh 42,157 mWh
    2016-07-12 - 2016-07-19 7,874 mWh 42,157 mWh
    2016-07-20 7,874 mWh 42,157 mWh
    2016-07-21 7,874 mWh 42,157 mWh
    2016-07-22 4,346 mWh 42,157 mWh
    2016-07-23 2,379 mWh 42,157 mWh
    2016-07-24 2,379 mWh 42,157 mWh
    2016-07-25 2,379 mWh 42,157 mWh
    2016-07-26 2,379 mWh 42,157 mWh
    2016-07-28T11:11:59+00:00
    The ability for my Surface Pro 3 (purchased in November 2014) to hold charge has diminished rapidly over the last few weeks. When I unplug it now, the battery charge drops within seconds from 100% to zero. Basically it turns off when I unplug it. If I shut it down first, unplug it and then power it up again when unplugged, it is on 1% and then almost immediately shuts down.
    2016-07-28T09:56:57+00:00
    My surface facing the same issue. Started happen just after run out of warranty :meh:
