2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-28T08:37:59+00:00
    I haven't read this entire thread but I strongly suspect the problem is with something called a fuel gauge IC built into the battery pack.  The IC is responsible for reporting the state of charge of the battery.  And it is reporting bad numbers.  The calculations performed by the IC are a little complicated and they have to take into account the size of the battery and the number of charge/discharge cycles (aging).  The IC is programmed at manufacturing and sealed up with the battery.
    So yes, it is a software problem.  The Simplo fuel gauge ICs were programmed with the wrong parameters.  But I don't know of any battery packs where you can reprogram the fuel gauge IC after manufacturing.
    2016-07-28T07:27:57+00:00
    it not works for my SP3
    2016-07-28T07:21:29+00:00
    Hi guys!
    Does the new firmware update solves the issue?
    I can't test it because my battery is at 0% and Windows doesn't let the firmware be installed with less than 40% battery. Firmware update files are also unavailable for downloading. All I could find was a link for 4/25/16 updates:https://www.microsoft.com/en-us/download/details.aspx?id=38826
    Does anybody have a link for 7/21/16 update?
    2016-07-28T06:05:37+00:00
