2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2017-11-12T15:27:33+00:00
    My keyboard only works when the battery is drained.
    2017-11-10T21:44:22+00:00
    My SP3 battery has given up altogether and now my device only operates off mains connection.
    MS have refused to replace or repair without payment of c.£400.00, which is not an option for me when the failure is due to a product fault and not misuse, neglect or excessive use.
    Shame on you Microsoft... shame on you.
    2017-10-03T17:47:11+00:00
    I would be more than happy to join in if language was edited to include lgc batteries. the lgc battery units are the ones that have become expensive paperweights.
    Agreed. I emailed Migliaccio to let them know I've been having problems with both batteries as well. Our company bought 6 SP3s (both battery types) - one of them won't work AT ALL if not plugged in (happened when it was 18 months old), none of the others will keep a charge for more than 20 minutes. Lovely that there weren't any problems until right after the 1 year warranty expired.
