2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-28T05:52:06+00:00
    Evey time I try the tips/tricks such as uninstalling the driver/disable the device in device manager, the degradation just becomes worse!
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1160976900
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 18,810 mWh
    CYCLE COUNT 364
    Battery capacity history
    Charge capacity history of the system's batteries
    2016-07-12 - 2016-07-19 27,664 mWh 42,157 mWh
    2016-07-20 - tried to "re-calibrate" 24,772 mWh 42,157 mWh
    2016-07-21 - plugged in when in use 24,350 mWh 42,157 mWh
    2016-07-22 23,337 mWh 42,157 mWh
    2016-07-23 -Plugged in when in use 22,423 mWh 42,157 mWh
    2016-07-24 - Plugged in when in use 22,032 mWh 42,157 mWh
    2016-07-25 - 21,664 mWh 42,157 mWh
    2016-07-26 - 20,490 mWh 42,157 mWh
    2016-07-27 19,760 mWh 41,342 mWh
    2016-07-28T03:06:08+00:00
    I also have this problem.  Surface Pro 3 purchased in March 2015, originally Windows 8 and upgraded to Windows 10 about 6 months ago.  Last 2 months the battery capacity has nosedived.
    What seems different in my situation is I always have the machine docked and the dock plugged into AC power (I use it as a desktop replacement - rarely use it on battery power) - and it will turn off after 4 hours now when docked as the battery is exhausted.  It only started doing this yesterday.  I have to then wait 20 minutes before I can turn it back on and get another few hours out of it, and repeat.
    The unit simply turning off when docked and plugged into AC power is annoying - I would have thought when docked it would not require the battery to have any charge.  I don't get any warnings about low power or anything - working away one second, the next blackness.
    Battery report
    COMPUTER NAME *******
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1450 05/27/2016
    OS BUILD 10586.494.amd64fre.th2_release_sec.160630-1736
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-07-2812:52:11
    Installed batteries
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1178279428
    CHEMISTRY LION
    FULL CHARGE CAPACITY 5,138 mWh
    CYCLE COUNT 198
    2015-03-16 - 2015-03-23 42,241 mWh 42,157 mWh
    2015-03-23 - 2015-03-30 42,558 mWh 42,157 mWh
    2015-03-30 - 2015-04-06 42,454 mWh 42,157 mWh
    2015-04-06 - 2015-04-13 42,583 mWh 42,157 mWh
    2015-04-13 - 2015-04-20 42,478 mWh 42,157 mWh
    2015-04-20 - 2015-04-27 42,583 mWh 42,157 mWh
    2015-04-27 - 2015-05-04 42,582 mWh 42,157 mWh
    2015-05-04 - 2015-05-11 42,565 mWh 42,157 mWh
    2015-05-11 - 2015-05-18 42,472 mWh 42,157 mWh
    2015-05-18 - 2015-05-25 42,435 mWh 42,157 mWh
    2015-05-25 - 2015-06-01 42,400 mWh 42,157 mWh
    2015-06-01 - 2015-06-08 42,532 mWh 42,157 mWh
    2015-06-08 - 2015-06-15 42,583 mWh 42,157 mWh
    2015-06-15 - 2015-06-22 42,583 mWh 42,157 mWh
    2015-06-22 - 2015-06-29 42,583 mWh 42,157 mWh
    2015-06-29 - 2015-07-06 42,583 mWh 42,157 mWh
    2015-07-06 - 2015-07-13 42,583 mWh 42,157 mWh
    2015-07-13 - 2015-07-20 42,583 mWh 42,157 mWh
    2015-07-20 - 2015-07-27 42,583 mWh 42,157 mWh
    2015-07-27 - 2015-08-03 42,583 mWh 42,157 mWh
    2015-08-03 - 2015-08-10 42,565 mWh 42,157 mWh
    2015-08-10 - 2015-08-17 42,583 mWh 42,157 mWh
    2015-08-17 - 2015-08-24 42,583 mWh 42,157 mWh
    2015-08-24 - 2015-08-31 42,583 mWh 42,157 mWh
    2015-08-31 - 2015-09-07 42,583 mWh 42,157 mWh
    2015-09-07 - 2015-09-14 42,583 mWh 42,157 mWh
    2015-09-14 - 2015-09-21 42,583 mWh 42,157 mWh
    2015-09-21 - 2015-09-28 42,583 mWh 42,157 mWh
    2015-09-28 - 2015-10-05 42,583 mWh 42,157 mWh
    2015-10-05 - 2015-10-12 42,583 mWh 42,157 mWh
    2015-10-12 - 2015-10-19 42,522 mWh 42,157 mWh
    2015-10-19 - 2015-10-26 42,570 mWh 42,157 mWh
    2015-10-26 - 2015-11-02 42,583 mWh 42,157 mWh
    2015-11-02 - 2015-11-09 42,583 mWh 42,157 mWh
    2015-11-09 - 2015-11-16 42,583 mWh 42,157 mWh
    2015-11-16 - 2015-11-23 42,579 mWh 42,157 mWh
    2015-11-23 - 2015-11-30 42,203 mWh 42,157 mWh
    2015-11-30 - 2015-12-07 42,203 mWh 42,157 mWh
    2015-12-07 - 2015-12-14 42,163 mWh 42,157 mWh
    2015-12-14 - 2015-12-21 41,945 mWh 42,157 mWh
    2015-12-21 - 2015-12-28 42,583 mWh 42,157 mWh
    2015-12-28 - 2016-01-04 42,583 mWh 42,157 mWh
    2016-01-04 - 2016-01-11 42,583 mWh 42,157 mWh
    2016-01-11 - 2016-01-18 42,583 mWh 42,157 mWh
    2016-01-18 - 2016-01-25 42,497 mWh 42,157 mWh
    2016-01-25 - 2016-02-01 42,583 mWh 42,157 mWh
    2016-02-01 - 2016-02-08 42,583 mWh 42,157 mWh
    2016-02-08 - 2016-02-15 42,583 mWh 42,157 mWh
    2016-02-15 - 2016-02-22 42,265 mWh 42,157 mWh
    2016-02-22 - 2016-02-29 42,339 mWh 42,157 mWh
    2016-02-29 - 2016-03-07 42,421 mWh 42,157 mWh
    2016-03-07 - 2016-03-14 42,583 mWh 42,157 mWh
    2016-03-14 - 2016-03-21 42,583 mWh 42,157 mWh
    2016-03-21 - 2016-03-28 42,583 mWh 42,157 mWh
    2016-03-28 - 2016-04-04 42,583 mWh 42,157 mWh
    2016-04-04 - 2016-04-11 42,583 mWh 42,157 mWh
    2016-04-11 - 2016-04-18 42,460 mWh 42,157 mWh
    2016-04-18 - 2016-04-26 42,583 mWh 42,157 mWh
    2016-04-26 - 2016-05-02 42,583 mWh 42,157 mWh
    2016-05-02 - 2016-05-09 42,583 mWh 42,157 mWh
    2016-05-09 - 2016-05-16 42,583 mWh 42,157 mWh
    2016-05-16 - 2016-05-23 42,583 mWh 42,157 mWh
    2016-05-23 - 2016-05-30 42,583 mWh 42,157 mWh
    2016-05-30 - 2016-06-06 39,011 mWh 42,157 mWh
    2016-06-06 - 2016-06-13 34,888 mWh 42,157 mWh
    2016-06-13 - 2016-06-20 32,475 mWh 42,157 mWh
    2016-06-20 - 2016-06-27 27,728 mWh 42,157 mWh
    2016-06-27 - 2016-07-04 22,078 mWh 42,157 mWh
    2016-07-04 - 2016-07-11 17,549 mWh 42,157 mWh
    2016-07-11 - 2016-07-18 14,901 mWh 42,157 mWh
    2016-07-19 10,724 mWh 42,157 mWh
    2016-07-20 9,038 mWh 42,157 mWh
    2016-07-21 8,223 mWh 42,157 mWh
    2016-07-22 8,223 mWh 42,157 mWh
    2016-07-23 8,223 mWh 42,157 mWh
    2016-07-24 8,007 mWh 42,157 mWh
    2016-07-25 6,684 mWh 42,157 mWh
    2016-07-26 6,498 mWh 42,157 mWh
    2016-07-27 7,721 mWh 41,981 mWh
    Current estimate of battery life based on all observed drains since OS install
    Since OS install 0:24:39 1:47:53<br><br>890 % / 16 h 3:22:17 14:45:15<br><br>108 % / 16 h
    2016-07-28T01:00:40+00:00
    I am also having this problem.  I remember when I got this Surface Pro 3 a little over a year ago and it was running Windows 8.  I can't remember if it was after an update or after I upgraded it to Windows 10 that the battery went form about 6 hours of run time to about 1.5-2 hours.  I would love to see a fix come out for this problem!
    In the info below you can see how my battery at full charge is less than half of what it was designed to be.
    Battery report
    COMPUTER NAME SS30
    BIOS 3.11.1150 12/09/2015
    PLATFORM ROLE Slate
    REPORT TIME 2016-07-2007:24:11
    Installed batteries
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1167202820
    CHEMISTRY LION
    FULL CHARGE CAPACITY 15,132 mWh
    CYCLE COUNT 270
    Recent usage
    Power states over the last 3 days
    2016-07-1812:52:02 Active Battery 40 % 6,392 mWh
    12:52:02 Connected standby Battery 40 % 6,392 mWh
    12:58:23 Connected standby Battery 30 % 4,720 mWh
    13:58:23 Suspended 28 % 4,454 mWh
    19:57:41 Connected standby Battery 25 % 4,028 mWh
    19:57:41 Active Battery 25 % 4,028 mWh
    20:05:53 Connected standby Battery 9 % 1,398 mWh
    20:05:53 Suspended 9 % 1,398 mWh
    20:07:08 Connected standby Battery 6 % 980 mWh
    20:07:08 Active Battery 6 % 980 mWh
    20:07:08 Active AC 6 % 980 mWh
    20:19:53 Connected standby AC 29 % 4,651 mWh
    20:19:54 Active AC 29 % 4,651 mWh
    20:19:55 Connected standby AC 29 % 4,659 mWh
    20:58:30 Active AC 74 % 11,704 mWh
    21:03:25 Active Battery 76 % 12,061 mWh
    21:03:42 Active AC 76 % 12,046 mWh
    21:08:47 Active Battery 78 % 12,396 mWh
    21:35:02 Connected standby Battery 56 % 8,968 mWh
    21:35:02 Active Battery 56 % 8,960 mWh
    21:35:36 Connected standby Battery 56 % 8,884 mWh
    23:20:29 Suspended 42 % 6,658 mWh
    2016-07-1908:00:42 Active AC 42 % 6,635 mWh
    08:00:42 Connected standby AC 42 % 6,635 mWh
    08:58:27 Active AC 95 % 15,132 mWh
    08:59:21 Connected standby AC 95 % 15,132 mWh
    08:59:22 Suspended 95 % 15,132 mWh
    09:00:02 Active Battery 100 % 15,132 mWh
    09:00:02 Active AC 100 % 15,132 mWh
    10:13:40 Active Battery 100 % 15,132 mWh
    10:13:46 Connected standby Battery 100 % 15,132 mWh
    10:13:49 Active Battery 100 % 15,132 mWh
    10:13:50 Connected standby Battery 100 % 15,132 mWh
    10:13:51 Active Battery 100 % 15,132 mWh
    10:13:52 Connected standby Battery 100 % 15,132 mWh
    11:13:52 Suspended 100 % 15,132 mWh
    12:40:04 Connected standby Battery 100 % 15,132 mWh
    12:40:04 Active Battery 100 % 15,132 mWh
    14:07:01 Connected standby Battery 27 % 4,058 mWh
    14:08:20 Active Battery 26 % 3,967 mWh
    14:21:31 Connected standby Battery 12 % 1,847 mWh
    14:21:33 Active Battery 12 % 1,847 mWh
    14:21:34 Connected standby Battery 12 % 1,839 mWh
    14:26:57 Active Battery 12 % 1,809 mWh
    14:28:15 Connected standby Battery 10 % 1,566 mWh
    15:28:15 Suspended 10 % 1,459 mWh
    2016-07-2007:23:54 Active Battery 8 % 1,246 mWh
    07:23:54 Active AC 8 % 1,246 mWh
    07:23:54 Report generated AC 8 % 1,246 mWh
    2016-07-27T23:26:56+00:00
    Hi Greg,
    My Surface Pro 3 won't run even a single second if not plugged in. If I remove the power cord from the Surface pro 3, it will simply lose power.
    I can't power it on without AC power.
    Battery status shows
    Plugged in not charging (85%)
    After going through all the methods suggested by Microsoft it still didn't resolve the issue.
    I did a reset of the slate as a last ditch effort which reloaded 8.1, but the problem stayed with the same battery status shown earlier. Then I upgraded it to Windows 10, but the battery status didn't change.
    I obviously have lost any past battery usage report  due to reset, but the current status remains the same as before.
    Do you think it's a software issue only?
    The machine has crossed warranty period.
    So I m at your mercy.
    But this is unacceptable.
    Regards
