2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-27T23:12:12+00:00
    Adding my name to the ever-growing list of people having the same issue.
    Here's my particular favorite from the battery report:
    2016-07-2716:50:43 Connected standby Battery 100 % 3,656 mWh
    16:50:43 Suspended 100 % 3,656 mWh
    16:59:38 Active AC 2 % 46 mWh
    100% to 2% in just under 9 minutes.
    I don't know how this is at all acceptable. I usually expect much better from Microsoft products. This should really be considered a top priority issue due to the number of people experiencing it and the impact (basically makes the device unusable).
    2016-02-01 - 2016-02-12 40,806 mWh 42,157 mWh
    2016-02-12 - 2016-02-14 40,880 mWh 42,157 mWh
    2016-02-14 - 2016-02-21 40,880 mWh 42,157 mWh
    2016-02-21 - 2016-02-28 40,880 mWh 42,157 mWh
    2016-02-28 - 2016-03-07 40,871 mWh 42,157 mWh
    2016-03-07 - 2016-03-13 40,857 mWh 42,157 mWh
    2016-03-13 - 2016-04-10 40,822 mWh 42,157 mWh
    2016-04-10 - 2016-04-17 42,235 mWh 42,157 mWh
    2016-04-17 - 2016-04-24 40,896 mWh 42,157 mWh
    2016-04-24 - 2016-05-01 40,896 mWh 42,157 mWh
    2016-05-01 - 2016-05-08 40,472 mWh 42,157 mWh
    2016-05-08 - 2016-05-15 34,526 mWh 42,157 mWh
    2016-05-15 - 2016-05-22 30,370 mWh 42,157 mWh
    2016-05-22 - 2016-05-29 28,568 mWh 42,157 mWh
    2016-05-29 - 2016-06-05 24,444 mWh 42,157 mWh
    2016-06-05 - 2016-06-12 23,868 mWh 42,157 mWh
    2016-06-12 - 2016-06-19 22,534 mWh 42,157 mWh
    2016-06-19 - 2016-06-26 18,674 mWh 42,157 mWh
    2016-06-26 - 2016-07-03 16,251 mWh 42,157 mWh
    2016-07-03 - 2016-07-10 11,709 mWh 42,157 mWh
    2016-07-10 - 2016-07-17 8,456 mWh 42,157 mWh
    2016-07-18 6,110 mWh 42,157 mWh
    2016-07-19 6,110 mWh 42,157 mWh
    2016-07-20 6,110 mWh 42,157 mWh
    2016-07-21 6,110 mWh 42,157 mWh
    2016-07-22 6,110 mWh 42,157 mWh
    2016-07-23 4,746 mWh 42,157 mWh
    2016-07-24 3,656 mWh 42,157 mWh
    2016-07-25 3,656 mWh 42,157 mWh
    2016-07-26 3,656 mWh 42,157 mWh
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1162156548
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 1,968 mWh
    CYCLE COUNT 136
    Here's a helpful graph for anyone who thinks this is "normal lithium ion degradation"
    2016-07-27T23:00:25+00:00
    Mine is the same. Hoping Microsoft comes up with a fix soon. Noticed a Firmware update went through earlier this week, but my battery life did not improve.
    2016-01-10 - 2016-01-17 41,396 mWh 42,157 mWh
    2016-01-17 - 2016-01-24 41,529 mWh 42,157 mWh
    2016-01-24 - 2016-02-01 41,423 mWh 42,157 mWh
    2016-02-01 - 2016-02-07 41,805 mWh 42,157 mWh
    2016-02-07 - 2016-02-14 40,999 mWh 42,157 mWh
    2016-02-14 - 2016-02-21 41,265 mWh 42,157 mWh
    2016-02-21 - 2016-02-28 41,486 mWh 42,157 mWh
    2016-02-28 - 2016-03-06 41,447 mWh 42,157 mWh
    2016-03-06 - 2016-03-15 41,680 mWh 42,157 mWh
    2016-03-15 - 2016-03-22 42,583 mWh 42,157 mWh
    2016-03-22 - 2016-03-27 42,583 mWh 42,157 mWh
    2016-03-27 - 2016-04-03 42,583 mWh 42,157 mWh
    2016-04-03 - 2016-04-13 42,583 mWh 42,157 mWh
    2016-04-13 - 2016-04-17 42,583 mWh 42,157 mWh
    2016-04-17 - 2016-04-28 42,583 mWh 42,157 mWh
    2016-04-28 - 2016-05-11 42,583 mWh 42,157 mWh
    2016-05-25 - 2016-06-01 35,561 mWh 42,157 mWh
    2016-06-01 - 2016-06-08 31,743 mWh 42,157 mWh
    2016-06-08 - 2016-06-15 28,055 mWh 42,157 mWh
    2016-06-15 - 2016-06-22 24,123 mWh 42,157 mWh
    2016-06-22 - 2016-06-29 19,338 mWh 42,157 mWh
    2016-06-29 - 2016-07-06 15,543 mWh 42,157 mWh
    2016-07-06 - 2016-07-13 11,474 mWh 42,157 mWh
    2016-07-13 - 2016-07-20 8,156 mWh 42,157 mWh
    2016-07-21 7,950 mWh 42,157 mWh
    2016-07-22 6,470 mWh 42,157 mWh
    2016-07-23 4,208 mWh 42,157 mWh
    2016-07-24 3,937 mWh 42,157 mWh
    2016-07-25 3,937 mWh 42,157 mWh
    2016-07-26 3,937 mWh 42,157 mWh
    2016-07-27T22:06:54+00:00
    My device was at full battery capacity at the start of 2016 and now has dropped 25%.  The device is going on three years old and I have not had any problems up until this time.  Based on all the comments I have seen in this post, I would say there is a definite cause and effect with this issue that must be resolved quickly.
    2016-07-27T21:21:54+00:00
    Looks like a 14% drop in capacity in about a month. That would be by no means reasonable in any device.
