2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
  1. Deleted
    2016-07-28T16:04:58+00:00
    It did not help. I was very hopeful but no use. All the suggested driver fixes are making it worse.
    Took a nose dive from 1,211mWh to 669mWh full capacity in 5 days.
    Now it ia literally a 'Desktop Replacement' as advertised, because it is literally just a desktop computer...
    2016-07-28T15:01:25+00:00
    I also have this problem in my sp3. Looking forward for solution
    2016-07-28T14:58:13+00:00
    Last week, I had a bit under 800 mWH capacity, now it's under 50!  To coin a phrase, this is Simplo unacceptable.
    I've had two people ask me about my Surface Pro 3 and I'd been recommending them to buy a Surface Pro 4 but I've now warned them that I can not endorse any Surface products and that they should look for something else.
    Six months to get WiFi reliable on Surface Pro 1. More WiFi issues at launch with Surface Pro 2 and firmware that left them unable to charge over Christmas 2015. Surface Pro 3 now has these battery issues which has been handled disgracefully with customers being asked to pay $99 for support followed by $450 for replacement. Surface Pro 4 and Surface Book which went through months of silence before Microsoft finally opened up and issued firmware updates to fix power management.
    I love my Surface Pro 3 and I hope that my mind can be changed and that Microsoft do something amazing to turn this around, reimbursing those out of pocket for example, and perhaps one day I can recommend the Surface brand again.
    EDIT: I will probably continue to buy Surface products, I love the design and form factor too much, but recommending others to spend their own money on them is something I will not currently do.
