2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-27T15:55:23+00:00
    Will this fix solve the problem I am having where a battery that is showing around 50% charge will suddenly drop to 0
    2016-07-27T15:36:16+00:00
    Greg,
    Does this apply to any device with Simplo batteries?  My Surface Pro 3 has an LG battery and the metrics look good. My Surface 3 does have a Simplo battery, but, the metrics seem ok at this time.
    2016-07-27T14:33:10+00:00
    I can't wait for this. Finally!
    2016-07-27T13:26:50+00:00
    retail
    bought in the UK from PC world sept 2014
    i reinstalled windows 8 a few months ago
    then i upgraded to windows 10  recently  to see if it would make any difference
    it did not
    i done the updates  for windows 10 after  i took the battery report
    it hasnt made any difference
