2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-27T13:26:37+00:00
    Battery report
    COMPUTER NAME SURFACE
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1150 12/09/2015
    OS BUILD 10586.212.amd64fre.th2_release_sec.160328-1908
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-07-27 11:04:55
    Installed batteries
    Information about each currently installed battery
    NAME X883815
    MANUFACTURER LGC-LGC
    SERIAL NUMBER 1154881796
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 29,518 mWh
    CYCLE COUNT 57
    Recent usage
    Power states over the last 3 days
    2016-07-27 10:59:59 Active AC 13 % 3,800 mWh
    10:59:59 Report generated AC 13 % 3,800 mWh
    I also have a SP3 with an LG battery and in the last 4 month or so the battery has been degraded 30%. I already posted my results in a few posts back.
    2016-07-27T13:02:26+00:00
    Same problem
    SP3 with SIMPLO batteries.  Purchased December 2014
    Since May 2016 full charge capacity has declined steadily from 42,583 mWh to current level of 1,005 mWh and will no longer run unless connected to mains AC power.
    Love my SP, but this is likely to turn into a PR disaster for Microsoft unless rapid resolution is forthcoming.
    Microsoft - please do not let us down.
    2016-07-27T12:59:55+00:00
    they say it is a firmware thing. so I don't think resetting to 8.1 would fix this. David Verheyen is (or was) the Rockingham Mall store manager. Contact him and refer him to this thread. I doubt Microsoft has gotten the info out to the stores yet but you did go before this info was posted by Greg. See if you can get Dave to exchange for a refurb.
    2016-07-27T12:55:34+00:00
    is this a retail or enterprise/education version of Windows?
    you should be at 10586.494
    check windows updates.
    Barb
    MVP-Windows and Devices for IT
