2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-27T12:42:54+00:00
    Hello everyone,
    We are aware of some customers reporting a scenario with their Surface Pro 3 batteries in which the system is reporting lower battery capacity than expected. We’ve isolated this to a limited number of customers experiencing this issue.
    Based on our investigations we can confirm that it is not an issue with the battery cells, and we believe this is something that can be addressed via software.
    We’re working through the details of how we deliver that.
    Thank you all for the details you've shared here,
    Greg
    Hi Greg,
    Interesting response, but I took by Surface Pro 3 to the Rockingham Mall Microsoft Store in NH on Monday, 7/25/2016, where the tech recommended a full reset.  Full reset to Windows 8 failed to address the Simplo Battery issue on my machine.  Battery does not charge, and SurfacePro must be connected to A/C power to operate.  Pull the A/C cord, and Surface Pro dies.
    The warranty expired 4/6/2016.  I have filed a claim for extended warranty with AMEX, but apparently I still need to pay $99 dollars to ship it to MS for a repair estimate, which is completely unsatisfactory.  I do not believe this is a software issue, but a serious hardware/battery defect.  Pretty sad performance of a machine I paid $1,415 for in Feb 2015.  My 2009 Apple Macbook Pro is still going strong, even with an original battery with 572 cycles.
    What say ye?
    What is the expected response for the "suggested" software fix?
    Will affected users still be able to download Win 10 after the 7/29/2016 deadline?
    Awaiting your community wide response.
    Margaret Bernier
    2016-07-27T12:31:10+00:00
    Glad to here this. I use a SP3 for work, and it simply won't work unless it's plugged in. Unplugging the cord causes it to shutdown immediately. Looking forward to having this fixed.
    2016-07-27T12:30:59+00:00
    Battery report
    COMPUTER NAME SURFACE
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1150 12/09/2015
    OS BUILD 10586.212.amd64fre.th2_release_sec.160328-1908
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-07-27 11:04:55
    Installed batteries
    Information about each currently installed battery
    NAME X883815
    MANUFACTURER LGC-LGC
    SERIAL NUMBER 1154881796
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 29,518 mWh
    CYCLE COUNT 57
    Recent usage
    Power states over the last 3 days
    2016-07-27 10:59:59 Active AC 13 % 3,800 mWh
    10:59:59 Report generated AC 13 % 3,800 mWh
    2016-07-27T12:16:28+00:00
    Yes I am one of those that paid the $450 to replace my device, please post any information on refunds as well.
