2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-27T12:12:47+00:00
    So far no LG battery Sufaces have been affected.
    Can you post your powercfg /batteryreport results here
    2016-07-27T12:06:40+00:00
    Why would the SIMPLO batteries have this problem and need a software fix but not the LG ones?
    My SP3 has LG batteries and is suffering from the same problem!
    Cheers
     Thomas
    2016-07-27T11:56:05+00:00
    Hi everyone,
    I have this problem too.
    Mine doesn't even get charged and I can't use my surface without power cord.
    I had 40% battery first time I faced the issue 6 months ago
    Now I have 0 percent.
    I tried reinstalling battery driver, factory resetting, and some solutions which were provided in different forums and none has worked so far.
    I live in Iran and unfortunately I don't have access to Microsoft's customer service :(
    It is really frustrating.
    I hope Microsoft releases a firmware update for this issue
    2016-07-27T11:50:47+00:00
    Its not just a simplo problem as I have an LGC battery
    Since feb this year I have only been able to use it with power supply , as soon as i unplugged it went off every time,
    it started off with 97% plugged in not charging. It is now 13% plugged in not charging
    I only  use it 2 or 3 times  a month for 3 hours
    When I contacted Microsoft after jumping through all the hoops ,I was told it was battery failure. 4 months out of warranty and they wanted £400 for a replacement with only 3 month warranty
    As someone else has said in a previous reply ,most of these problems started around early 2016,
    so hopefully it is a software problem
    Information about each currently installed battery
    NAME X883815
    MANUFACTURER LGC-LGC
    SERIAL NUMBER 1154881796
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 29,518 mWh
    CYCLE COUNT 57
