2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-27T19:16:58+00:00
    as I mentioned on page 20, this is not just a SP3 issue.
    my SP4 has the same problem too:
    Installed batteries
    Information about each currently installed battery
    NAME X910528
    MANUFACTURER DYN
    SERIAL NUMBER 42339
    CHEMISTRY LION
    DESIGN CAPACITY 38 mWh
    FULL CHARGE CAPACITY 30 mWh
    CYCLE COUNT 172
    If you take a closer look at all the reports, you can clearly see that this started around March/ April.
    I am quite confident that we will see more and more people checking their SP3 or SP4 realizing that this is not just a SIMPLO issue..
    DYN is also a LGC battery!
    2016-07-27T18:52:21+00:00
    I have a Surface Pro 3 i5.  The battery life has diminished. Unless I pay a $99 fee I cannot get any support help. I have seen a couple of articles that are telling similar experiences that I am having. It seems batteries in earlier model Surface Pro 3's are no longer holding their charges.  I have done all of the battery saving setups and checks but the battery is just not giving me the 'life' I used to be able to get.
    Is Microsoft checking out the batteries; since it seems to be a noticeable issue in the articles?
    What are the plans of Microsoft to assist those of us with battery life issues?
    2016-07-27T17:31:06+00:00
    LDJ thank you my question was incomplete.  I have an SP3.  It is two years old.  It was very stable for 18 months or so.  Over the last 6 months it has developed a quirk where it drops rapidly from around 50% +/- a few % to 0 in a minute or two.  I am wondering whether the proposed software fix might alleviate this issue.
    2016-07-27T16:08:04+00:00
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=f1fee102-5a03-4c2f-9d9c-5b29abb7dcae)
    Experiencing varied and often poor battery life on my six month old Surface Pro 4 too. See above...
