2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-06-19T10:39:33+00:00
    Unfortunately, I have the same problem with my Surface Pro 3 i7 / 256GB. Also, over the warranty period. In my case, the battery has only 84 cycles of charging and its degradation is over 80%. It's an obvious flaw factory model, which could not be detected during the warranty period. My warranty ended this month. Microsoft should replace a faulty device, which sells at a very high price. The price at which you can expect a solid device operating years. !\[\](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=c07630a7-2034-4739-b11b-7a35296a15be)
    2016-06-19T06:26:33+00:00
    I have similar problem with the battery of my SP3...
    Battery capacity history
    Charge capacity history of the system's batteries
    2015-11-16 - 2015-11-30 41,404 mWh 42,157 mWh
    2015-11-30 - 2015-12-07 41,584 mWh 42,157 mWh
    2015-12-07 - 2015-12-14 41,632 mWh 42,157 mWh
    2015-12-14 - 2015-12-21 41,734 mWh 42,157 mWh
    2015-12-21 - 2015-12-28 41,182 mWh 42,157 mWh
    2016-04-18 - 2016-04-25 37,536 mWh 42,157 mWh
    2016-04-25 - 2016-05-02 34,977 mWh 42,157 mWh
    2016-05-02 - 2016-05-09 32,106 mWh 42,157 mWh
    2016-05-09 - 2016-05-16 27,637 mWh 42,157 mWh
    2016-05-16 - 2016-05-23 23,582 mWh 42,157 mWh
    2016-05-23 - 2016-05-30 20,805 mWh 42,157 mWh
    2016-05-30 - 2016-06-06 16,858 mWh 42,157 mWh
    2016-06-07 14,163 mWh 42,157 mWh
    2016-06-08 13,387 mWh 42,157 mWh
    2016-06-09 13,201 mWh 42,157 mWh
    2016-06-10 13,201 mWh 42,157 mWh
    2016-06-11 13,119 mWh 42,157 mWh
    2016-06-12 12,548 mWh 42,157 mWh
    2016-06-13 12,098 mWh 42,157 mWh
    2016-06-14 11,012 mWh 42,157 mWh
    2016-06-15 10,898 mWh 42,157 mWh
    2016-06-16 10,558 mWh 42,157 mWh
    2016-06-17 10,122 mWh 42,157 mWh
    2016-06-18 9,943 mWh 42,157 mWh
    2016-06-18T13:54:40+00:00
    I use my Surface Pro 3 a lot and so my battery cycle is at 323.
    My warranty just expired last March and I bought my machine Thanksgiving 2014 here in the US.
    Now I have to pay $99 for every contact to Microsoft Technical support.
    I have not tried going to the store to have it checked out yet.
    Battery started to degraded drastically after my warranty just expired.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=d9715fea-8fb7-44b6-8bf4-170444d582d8)
    2016-06-17T12:52:15+00:00
    I am seeing the same issue.  I really starting noticing this after the System Hardware Update - ‎1/‎19/‎2016.  I am not sure it is related, but I noticed this issue and the random reboots/freezes when the system goes into hibernation.  I held off removing the update because I wasn't sure they were related however the more I think about it that update has definitely made things worse.
    Justan Welch
