2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-06-20T12:54:28+00:00
    I am also having this problem. ~55% degradation in about 6 weeks. My SP3 is 18mo old; drop in capacity started in May.
    FWIW, it seems like my SP3 is getting a lot hotter than it used to when it is plugged in. Batteryreport is also reporting ~950 charge cycles, which I definitely is NOT something that happened on my end. Maybe it's a firmware issue?
    2016-06-19T17:14:33+00:00
    I have had to pay £400 to get mine replaced, which hurts a lot. Especially as my Son has one too and I expect I will have to pay another £400 to get his fixed shortly.
    I have gone from the "Best device in the world" to only buy if you are stupid rich.
    My Advice, is simply to get enough people reading this thread, until a Journalist picks up the story, once the press knows there is a problem Microsoft will have to give us back the money we spent or face losing the Surface brand forever.
    There is a tread on Reddit too.
    Good luck
    2016-06-19T13:05:09+00:00
    What can we do in such a situation to Microsoft exchanged or fixed our faulty equipment? Disadvantages could not discover during the warranty period. In another thread I read that a normal battery capacity decrease is 10% to 100 charge cycles. In our case it is more than 80%, which testifies to the erroneous action of management, and its factory defect.
    Regards
    2016-06-19T12:49:03+00:00
    I have exactly the same problem: my surface pro 3 is one year old: and lately, since the last month i would say, the battery is running low faster and faster.. - I can now not work on battery for not even 2 hours  and i have the idea that each time it is shorter and shorter;...
