2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-06-07T22:26:44+00:00
    I feel quite let down by microsoft on this, posted on Reddit and on Spiceworks as well as this site, I think the only hope is to get as much noise about this issue on the forums that it starts to threaten future sales of the surface pro series, as I think there will be some kind of reasonably priced option. Nobody wants to buy this product knowing that that stand a 10% chance of total loss after just 13 months.
    I think there will be many thousand devices affected - just need to find the owners and get them to post about the issue.
    I was wondering if anybody could find that AMA microsoft did which quoted the $200 dollars.
    Surface Pro 3
    SurfacePro3
    SIMPLO
    Battery_report
    capacity
    powercfg
    2016-06-06T20:14:36+00:00
    I bought my pro 3  from PC world in  sept 2014 ,i rarely used it only when away from home
    Feb  this year i had the not charging  90% battery but every time i took the charger off it died
    went through all the steps with the support and was told it was battery failure and would have to have it replaced out of warranty  for £260
    they then told me I should  take it back to the shop under EU legislation it should be guaranteed for at least 2 years under faulty goods act
    i went into PC world who fobbed me off and told me i had to contact head office about out of warranty
    I contacted PC world by phone and they got back to me an hour later and told me they do not repair tablets and i had to take it to a shop for repair and they would pay the bill
    I contacted a computer shop and was told its a sealed unit and they would not  attempt to replace the battery
    I phoned PC world the next day and got a different person in the dept who told me he has had a few problems with them and yes its a sealed unit and can only be fixed properly by replacing the unit , he then told me his manager was out and would speak to him about making me an  offer
    he phoned back 15 mins later and offered me £532  as i had already had 18 months usage from it
    I took their offer
     I still have the pro3 but when i contacted microsoft about a replacment  the price had gone up to £400  only a week later and its only 3 month warranty with the replacement
    same thing could happen in 6 months time  as i had very little usage on it maybe 3 or 4 times for about 3 weeks at a time
    I can still use it when its plugged in so have not replaced it yet
    2016-06-06T15:52:28+00:00
    In my country (Thailand) there is an Office of Consumer Protection Board, that I will try to contact, but I doubt they will be any help. My charging cycle is now at 80. It was around 73 before this happens. There's no way a battery could degrade this much to the point it's no longer hold any power in just 80 cycles.
    To be honest, I don't mind paying for a battery replacement, but paying for a refurbished machine without someone taking a look at it for what seemed to be a defect is simply too much for me. What's more annoying is, I just found out it's cheaper in the US. Sigh.
    There is simply no equivalent of "Have you tried reinstalling Windows?" equivalent for hardware.
    Speaking of Reddit, I wonder what happened to the $200 battery replacement promise?
    2016-06-06T06:42:09+00:00
    Mine went at 13 months old same Manufacturer "SIMPLO", I spoke to Microsoft who have confirmed it can not be fixed and now I must take it back to the shop I purchased it from.
    I expect the shop will not take it back - The device is not fit for purpose but that will be a battle, but I do have UK law on myside.
    I suggest we update each other on any success
    Think I will try on Reddit as well
