2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-06-05T20:01:19+00:00
    Simon,
    Thanks for the kind words. I have also found someone with the same problem. Accidentally, the person's battery also start degrading a little bit after a year of usage (same as mine). Both me and him are using battery manufactured by "SIMPLO" as reported from powercfg.
    Anyway, no way I'd pay $560 for a replacement. So here's my current battery capacity:
    This lasts about 5 seconds. I unplug the charger by mistake, and the machine is already shutting itself down.
    Kridsada
    2016-06-05T16:05:57+00:00
    Kridsada,
    You are not the only person with this issue, I have found a growing number - either the battery manufacturer made a mistake or a firmware update has caused the issue (such as frying the battery by staying turned on in a bag).
    I believe that you are simply one of the first to get the problem, once there are a few thousand people with the same problem the Bad PR will stop the surface book sales dead.
    So carry on posting, this is not your fault, and should not be your cost.
    Simon
    2016-05-20T01:56:32+00:00
    I have attempted all suggestions as well as all others I could track down in various blogs and posts. Sadly it is apparent that the battery is no longer functional and able to hold a charge. Even when the indicator shows 100%, once unplugged, the Surface Pro 3 turns itself off in a matter of minutes. And even more sadly, the machine design, while extraordinary in many ways, is hugely flawed in the power arena. Specifically, the battery can simply not be replaced at any price. A replacement machine is not am appealing solution as it is refurbished and brings all of its own risks while putting me through the rigors and pain of having to set up everything anew.
    My hope is that I can continue to use the Surface Pro 3 while in the docking station or plugged in to a standard outlet. However, there are times when work and life require me to be untethered. Can anyone recommend a portable power supply solution that I could purchase to use during those times? Most of what I am seeing is directed toward re-charging the battery (which is a fool's errand in my situation). What I need is something portable enough and powerful enough to plug in to the USB port or into which I can plug the standard wall charger that will allow me to work and read for a couple of hours.
    Any suggestions greatly appreciated. Thank you.
    2016-05-19T10:37:43+00:00
    1. just to be sure, the replacement cord was not for the docking station.
    2. you can order another replacement cord to see if in fact it makes a
    difference
    1. if you are in the US, you can go to the nearest physical retail store and
    they will test your Surface and power adapter.
    Barb
    MVP-Windows and Devices for IT
