2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-05-18T17:43:05+00:00
    I have a very similar problem and very similar Battery Report. I generally use a docking station but it seems like the battery issue might have started right after I switched over to the replacement power cord MS sent on the recall last month. Has anyone else had that experience? Any solution to the roller coaster battery performance? As I wrote this, mine jumped from 30% to 100% for no apparent reason. Thank you.
    2016-05-12T16:23:53+00:00
    Hello Kridsada Thanabulpong,
    Sorry to hear you are still having an issue. Unfortunately, at this point this would have to be handled by our Assisted Supportdue to it being a Warranty/Service issue because you have tried all of the troubleshooting.
    Best Regards
    2016-05-12T00:10:06+00:00
    HelloKridsada Thanabulpong,
    Thank you for reaching out to the Surface community. Sorry to hear you are having issues with your battery. If you do in fact have a hardware issue it would be a Warranty/Service related issue that you would have to contact Assisted Support to resolve if you do not have a Microsoft Store in your country. However, to try to determine what is going on with your Surface's battery please follow the troubleshooting steps in this link.
    Please reply with what steps you've tried and what the results were.
    Best Regards
    2016-05-03T02:16:57+00:00
    Dear all
    I got my Surface Pro 3 in Dec 2014, and now the battery only has 20 mins or less and the battery is dying
    Is this a problem with hardware or software update ?
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=a4646329-c22f-4da3-913e-31d9698c32aa)![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=1422cb85-c188-4c2a-8808-7e03fb1d764d)
