2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2017-10-03T10:37:09+00:00
    I wish everyone would contact the US Lawsuit that Migliaccio in Washington DC have been compiling - EVEN IF YOU ARE NOT IN THE USA CONTACT THEM!
    http://www.classlawdc.com/2016/07/26/migliaccio-rathod-llp-investigates-microsoft-surface-pro-3-battery-failures/
    2016-04-19T06:12:37+00:00
    I have experienced this case multiple times and I can't find out what happened
    I hit the power button and after 15 minutes, the computer will go into suspension mode (hibernate)
    and after several hours I found that the back of the machine stay warm,
    and I cannot wake it up - when I hit the power button again, I can see the monitor is on, and nothing showing up except a black screen
    I pushed power button for 10 seconds and force rebooting it,
    and then 30% of the battery is gone (100% sure something is running / stucked at background, but no way to find out)
    This is the battery report, the computer is (supposingly) suspended at 10:33:00 at 73% battery level,
    and wake up at 13:23:25, and almost 30% of battery is gone
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=2c923c76-9201-465c-8b51-79b56604bcad)
    And the powercfg can't log any activity for sure
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=57767344-729b-4b2b-b30f-5932217895c8)
    How can I prevent this? Does it related to windows update or what? Thanks
    2016-04-10T23:51:16+00:00
    I don't know what's up, but the battery life of the surface is horrendous, and it's getting quite annoying. I am simply browsing on the web with one tab, and the battery depletes much faster than it should, with nothing running in the background. I have also installed all updates. Is there any way I can have better battery life and be able to use my surface without it heating up?
    2016-03-17T11:04:39+00:00
    If you've been through everything at
    https://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/surface-wont-turn-on-battery-wont-charge?os=windows-10
    then you need to contact support
    https://www.microsoft.com/surface/en-us/support/contact-us
    Barb
    Windows Experience MVP
