2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2017-10-03T10:36:30+00:00
    Well said AndyD311.
    I wish everyone would contact the US Lawsuit that Migliaccio in Washington DC have been compiling - EVEN IF YOU ARE NOT IN THE USA CONTACT THEM!
    http://www.classlawdc.com/2016/07/26/migliaccio-rathod-llp-investigates-microsoft-surface-pro-3-battery-failures/
    2017-09-27T16:31:49+00:00
    if you dont have  40% battery power no update fix will work anyway
    they never came up with a solution to get round that so they just ignore everything now and split up the previously massive threads about it
    2017-08-12T04:17:14+00:00
    Well .. to me, I'm happy to see Consumers Reports to remove Surface PCs. I love the products and paid for SP3 and subsequently SP4. Had this problem on SP3 and I still remember during the early days, no one helped especially from Microsoft. All they could do is "your unit is out of warranty, but you can pay xx dollar and we'll replace the battery for you. That was when the "firmware" was out to fix the charging issue.
    For almost 2 months, I had to suffer for this inconvenience. No sorry, no thank you no nothing from Microsoft.
    And now this PANOS PANAY comes out to defend because he's highly paid to do so. **** idiot and will not change my mind to reject and never recommend Surface for any of my friends.
    2017-08-12T03:28:21+00:00
    I guess consumer reports is spot on with their terrible review of the Surface and lack of reliability and "no longer recommends" and neither do I.  I have also advised the company that I work for to avoid them.
    I too have a SP3 that no longer detects the battery and can no longer run without being connected to power adapter, that was just out of warranty when it stopped functioning..  Unacceptable Microsoft...
