2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2017-09-27T16:24:17+00:00
    Suggestion 1
    Never by or recommend Microsoft hardware again
    Suggestion 2
    Microsoft will screw you.
    2017-07-19T02:47:22+00:00
    one year later, and still no solution?
    2017-01-31T13:27:50+00:00
    The recent November 2016 Firmware Update also killed my Surface Pro 3(Windows 10).  I receive the message "Plugged in, not charging at 66%", and when I remove A/C power the SP3 instantly shuts down.  I have also lost any ability to join a Wireless Connection. The Wi-Fi displays that there are no connections available...But there are.  I really hope Microsoft soon releases a fix for the SP3, as these issues have made it unusable.
    2016-07-19T16:55:36+00:00
    My Sufrace SP3 has two years and I'm not having issues with his battery, but battery's manufacturer is LGC-LGC.
