2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-26T15:18:57+00:00
    2016-07-26T14:57:58+00:00
    Posting here and there won't do much.  Somebody who knows a product liability attorney needs to find out if this qualifies for a class action suit.  That will likely be the only way to wake Redmond up.
    2016-07-26T14:50:35+00:00
    Very interesting, thanks! If anybody tries this and succeeds, please let us know!
    2016-07-26T14:48:39+00:00
    Less than 10 seconds when plugged in?
    I think mine is starting to do something similar. Every once in a while when plugged in it just dies. If the thing is a brick less than two years after purchase then this was a huge waste of money Microsoft.
