2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-26T14:40:22+00:00
    Hello Everyone!
    When I had posted my success case where I have recovered the battery capacity after the apparent degradation, I have omitted to mention one additional step that I´ve done, but not I gave importance at that time, but perhaps it is important because it may be "reseting" some parameter with the battery charge.
    After reinstalling the driver, I make a “disable” the driver (course while plugged), this disables the battery for the OS and it looks as if there is not a battery installed or as if we take out the battery from the computer (attached screen how to do this).
    Don´t panic, after restart the computer, manually re-enable the driver and return to appear the battery and continue with the method of charge described, in where the battery, in my case, charges a little more each day until its recover his full capacity.
    As I said before, perhaps this action reset any parameter with the battery and started charging again at 100%.
    I hope this helps and could try this method and comment, because it is worse to have the battery maybe apparently degraded.
    I was monitoring the behavior these days and almost to today my SP3 with battery SIMPLO so far continuous holding its maximum design capacity.
    Greetings,
    Juan Manuel (Juanmaq)
    2016-07-26T14:36:09+00:00
    Mine lasts less than 10 seconds off of a power connection.  All of this has happened in the last 5 weeks or so.  If I wanted a desktop, I would have bought a desktop.  Running the powercfg command shows my battery has 44 mWh capacity. And, this is a replacement for one that experienced the not charging problem earlier this year.  Simply shameful.
    2016-07-26T13:37:48+00:00
    Same here. SP3, SIMPLO battery full charge capacity went down from 42521 mWh in April to 144 mWh in July. Device only runs with charger plugged in.
    2016-07-26T13:25:33+00:00
    Add me to the list SP3 owners with SIMPLO battery woes.  It is now a power cable dependent slate.
