2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-26T11:53:44+00:00
    You think that is bad?  I can't even remove my surface from power without losing power!
    2016-07-26T11:35:43+00:00
    You should definitely avoid running your SP3 on battery as much as possible.  I tried fully discharging mine to do a full charge, sitting at the UEFI (BIOS) to rule out Windows drivers, and this was the result (see results from 21st to 22nd)
    Thanks, I'll stick to the power supply while at home, then. Shame, though...
    2016-07-26T11:29:32+00:00
    I am located in Singapore. There is a repair shop that can replace the battery. klazz.biz. They advise it will cost S$180.00 including battery and cost of labor.
    However, they advised that only 1 model of the battery is available. I believe it is Model 1645. Unfortunately, my model is 1631. No luck. If any of you reside in Singapore and has battery model 1645, you can check them out...
    Is there a way to check model of battery in SP3?
    2016-07-26T10:59:07+00:00
    Do you think I should avoid unplugging the SP3 whenever possible? Maybe that would at least prevent faster battery degradation? I usually work at home, and rarely actually take the Surface out of the house...
    You should definitely avoid running your SP3 on battery as much as possible.  I tried fully discharging mine to do a full charge, sitting at the UEFI (BIOS) to rule out Windows drivers, and this was the result (see results from 21st to 22nd):
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=f9f5bab6-cfa3-4e59-b5d8-3f2f4a4912a1)
