2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-26T10:51:16+00:00
    I even booted into Linux from USB and checked the battery to rule out any windows driver issues, no luck at all. Not a driver issue.
    2016-07-26T10:44:19+00:00
    This is exactly the problem I am facing.
    It happened in mid July.
    Tried everything including a reset. It went back to 8.1 and then I upgraded to 10. The problem persists
    Plugged in not charging battery status 85%
    Now I cannot use it without AC power!!!!!
    Please help.
    2016-07-26T10:35:20+00:00
    clarifying this - MVP's and Community Moderators are unpaid volunteers and do
    not work for Microsoft. MVP's are able to get a support incident (but we have to
    give OUR credit card numbers) - if it is a software bug, this is how to get it
    in front of engineers. I was asked by a Microsoft Surface Supportability person
    who knows how MVP's can open cases to get a few cases opened.
    The battery issue - same person stated it was out of his hands. They obviously
    have duplicated it internally and do not need support cases. They were unable to
    duplicate the Code 45 thing.
    My personal opinion of the battery issue is that it is shameful.
    >>Just to highlight where Microsoft's priorities are we actually received a response from a Microsoft representative offering FREE support calls because of a driver issue (reporting error code 45) but a systemic hardware failure? Oh no, that requires us to get through a $99 paywall and has received ZERO response from Microsoft.
    Barb
    MVP-Windows and Devices for IT
    2016-07-26T10:35:16+00:00
    Hello everyone,
    I own a SP3 and have just found out about this. Turns out my SP3 also is installed with a SIMPLO battery, but since my battery cycle is relatively low, the charge capacity is still reasonable.
    Do you think I should avoid unplugging the SP3 whenever possible? Maybe that would at least prevent faster battery degradation? I usually work at home, and rarely actually take the Surface out of the house...
    Here are my battery details:
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=3bb73198-5761-42e8-a224-33a1e34f54ae)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=78e00569-e292-403b-bb14-fd0a6fabdd6c)
