2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-26T19:49:30+00:00
    So basically:-
    Revert battery driver and reboot
    Update battery driver and reboot
    Disable battery driver and reboot
    Reenable battery driver and reboot
    Is that correct?
    2016-07-26T19:19:13+00:00
    I also have the battery problems. My final full charge capacity is 631 which leaves me with almost enough time to gasp for breath before my tablet eats it. So much for my beloved computer.... FIX THIS MICROSOFT.
    2016-07-26T17:35:04+00:00
    This is very disappointing and disturbing.  Like the rest of you, my Surface Pro 3 battery life started to disintegrate within the past month.  Over the next month or so, I will not be in a position to plug in, but use of my device will be extremely important.  Not sure what the solution might be, but so very disappointed to learn Bill and Melinda Gates, who are now so enthusiastic about giving away their wealth to charity will not make good on their obligations to their customers who enabled them to accumulate wealth in the first place.
    2016-07-26T15:27:22+00:00
    I saw a steep decline in battery life over the past few months, followed by a slow partial recovery in the past week. At this point still well below battery spec, but somewhat better than at its worst. I did not log every step I took to try to recover the battery, but as near as I can reconstruct, here is what I did: applied latest firmware update, applied latest update for Windows 10, turned off most background app notifications, reduced screen brightness, began using the Surface Pro 3 unplugged to drain the battery fully prior to charging whenever possible. For reference: Surface Pro 3 i7 256 GB SIMPLO battery. Here's the recent history from powercfg /batteryreport.
    2016-03-20 - 2016-03-28 41,489 mWh 42,157 mWh
    2016-03-28 - 2016-04-03 41,423 mWh 42,157 mWh
    2016-04-03 - 2016-04-11 40,724 mWh 42,157 mWh
    2016-04-11 - 2016-04-17 32,879 mWh 42,157 mWh
    2016-04-17 - 2016-04-24 29,940 mWh 42,157 mWh
    2016-04-24 - 2016-05-01 33,718 mWh 42,157 mWh
    2016-05-01 - 2016-05-09 31,620 mWh 42,157 mWh
    2016-05-09 - 2016-05-16 28,589 mWh 42,157 mWh
    2016-05-16 - 2016-05-22 24,927 mWh 42,157 mWh
    2016-05-22 - 2016-05-29 20,304 mWh 42,157 mWh
    2016-05-29 - 2016-06-05 18,425 mWh 42,157 mWh
    2016-06-05 - 2016-06-12 20,776 mWh 42,157 mWh
    2016-06-12 - 2016-06-19 25,669 mWh 42,157 mWh
    2016-06-19 - 2016-06-26 23,226 mWh 42,157 mWh
    2016-06-26 - 2016-07-03 18,562 mWh 42,157 mWh
    2016-07-03 - 2016-07-10 14,137 mWh 42,157 mWh
    2016-07-10 - 2016-07-17 11,021 mWh 42,157 mWh
    2016-07-18 9,794 mWh 42,157 mWh
    2016-07-19 10,461 mWh 42,157 mWh
    2016-07-20 11,458 mWh 42,157 mWh
    2016-07-21 12,143 mWh 42,157 mWh
    2016-07-22 12,967 mWh 42,157 mWh
    2016-07-23 13,592 mWh 42,157 mWh
    2016-07-24 14,014 mWh 42,157 mWh
    2016-07-25 14,748 mWh 42,157 mWh
