2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-25T23:37:43+00:00
    I'll add my voice as well.  Just recently started seeing rapid discharge of battery.  I ran the battery command, and sure enough I have the simplo battery as well.  I find it unacceptable that Microsoft would charge to fix a massive battery issue they are facing.  I hope that they will rectify this shortly, as now I will not be encouraging others to purchase a Microsoft product.
    I've already gone to Amazon and rewrote my review on the MS Surface Pro 3 telling people NOT TO BUY THEM due to this battery issues and MS's inability to respond to this issue. They've had plenty of time to address this. Time to start spreading the news!
    2016-07-25T23:27:11+00:00
    Here is the important part of the report that EVERYONE should check...  At the two arrows below show the original design capacity in mWh (milliwatt hours) and the full charge capacity in mWh. What my report shows is that is was designed to charge to 42,157 mWh but it actually has reduced itself to full charge of 144 mWh which equates to minutes after being unplugged.  Today, when I unplug, it shuts off.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=24899819-7ae8-495a-a800-407ea89a7d8e)
    2016-07-25T23:14:06+00:00
    OK, so this is more widespread than I could have imagined.  Today after about my tenth phone call to support since my battery started degrading 2 months after the warranty expired , I was ready to give in, but then...
    I was told by support that I would need to pay $450, I knew this from many other phone calls and was ready to give in since I use this for my business.  Then they told me I would have to send it in and wait form my new used (refurb) Surface Pro 3 somewhere between 8-10 business days after they receive it.  Now, just imagine me running my business from my iPhone (because I ditched my Windows phone about 6 months ago).
    Can anyone tell me how we can start a class action lawsuit while I order my new MacBook Pro?
    2016-07-25T21:35:25+00:00
