2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-25T18:51:26+00:00
    I want to add my voice to this apparent growing problem.
    I have a surface pro 3 with the SIMPLO Batter which now shows a Full Charge Capacity of 144 mWh.
    It is a couple months out of warranty so I'm in the same boat of many people here with a device designed for portability that is no longer fit for purpose.
    My attempts to talk to Microsoft regarding this have been met with pay-walls for service when trying to do so from home via phone or online.  Luckily I have a Microsoft store within an hour's commute to talk to their support staff at no cost.  This resulted in an offer of a replacement (in store) for a cost of $550 Canadian. I insisted on seeing the powercfg /batteryreport output of the replacement before agreeing. It also had a SIMPLO batter installed and with only a 90 day warranty on that device with no opportunity to extend the warranty, this was an offer to replace a known defective device with a known defective device.
    The blank looks or silence when mentioning that this is a much talked about, discussed and apparently a widely spread issue, are very disappointing.
    I was planning on purchasing a second device for my wife to use because she likes it so much.  Given the way Microsoft has dealt with what appears to be a ticking time-bomb of faulty hardware that only happens to become evident after the warranty expires, I can't justify spending another cent on Microsoft hardware.
    I also can't recommend to my employers any surface devices for their mobile computing... though I expect they treat their business customers a little better than regular consumers.
    2016-07-25T13:57:19+00:00
    But look at where most people had the issue, January 2016.
    2016-07-25T13:56:52+00:00
    My battery report.  Like many others I started seeing rapid degradation starting in April.
    Battery report
    COMPUTER NAME ELF-SURFACE
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1450 05/27/2016
    OS BUILD 10586.494.amd64fre.th2_
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-07-25 09:49:05
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1165761028
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 144 mWh
    CYCLE COUNT 105
    Recent usage
    Power states over the last 3 days
    2016-07-2210:24:00 Connected standby AC 100 % 144 mWh
    10:58:15 Active AC 100 % 144 mWh
    14:27:00 Suspended 74 % 106 mWh
    19:46:57 Active AC 16 % 23 mWh
    20:08:42 Connected standby AC 100 % 144 mWh
    2016-07-2316:01:03 Active AC 100 % 144 mWh
    16:01:37 Connected standby AC - -
    16:06:11 Active AC 100 % 144 mWh
    16:06:44 Connected standby AC 100 % 144 mWh
    21:09:47 Active AC 100 % 144 mWh
    2016-07-2416:55:06 Connected standby AC 90 % 129 mWh
    16:55:14 Active AC 90 % 129 mWh
    17:25:01 Connected standby AC 85 % 122 mWh
    18:27:00 Suspended 85 % 122 mWh
    2016-07-2509:06:26 Active AC - -
    09:49:00 Report generated AC 32 % 46 mWh
    Battery usage
    Battery drains over the last 3 days
    Usage history
    History of system usage on AC and battery
    2015-12-27 - 2016-01-03 1:53:37 3:27:56 111:21:16 42:38:22
    2016-01-03 - 2016-01-10 1:48:22 9:02:15 42:51:20 102:55:01
    2016-01-10 - 2016-01-17 10:18:03 42:56:30 24:54:24 72:02:28
    2016-01-17 - 2016-01-24 1:29:24 30:17:43 21:31:02 90:31:54
    2016-01-24 - 2016-01-31 2:21:42 0:49:51 45:15:38 119:50:20
    2016-01-31 - 2016-02-07 3:09:27 82:06:46 15:39:29 66:30:16
    2016-02-07 - 2016-02-14 4:54:40 81:53:07 9:30:05 49:38:08
    2016-02-14 - 2016-02-21 6:03:58 42:37:59 32:15:46 55:06:38
    2016-02-21 - 2016-02-28 1:12:43 1:05:09 71:23:27 93:14:21
    2016-02-28 - 2016-03-06 - - 105:12:13 62:31:28
    2016-03-06 - 2016-03-13 0:36:51 3:13:40 88:00:22 72:49:45
    2016-03-13 - 2016-03-20 0:04:34 0:00:05 73:22:11 94:52:34
    2016-03-20 - 2016-03-27 0:01:37 0:00:02 82:14:01 85:31:46
    2016-03-27 - 2016-04-03 3:10:04 0:00:10 199:42:25 298:01:37
    2016-04-03 - 2016-04-10 7:06:54 5:36:25 296:24:00 350:40:40
    2016-04-10 - 2016-04-17 - - 117:37:18 49:26:40
    2016-04-17 - 2016-04-24 0:34:23 0:08:38 226:08:55 107:41:31
    2016-04-24 - 2016-05-06 0:01:55 72:11:15 56:02:17 24:44:27
    2016-05-06 - 2016-05-08 - - 22:53:27 20:07:51
    2016-05-08 - 2016-05-15 - - 68:29:28 99:41:27
    2016-05-15 - 2016-05-22 - - 68:46:32 99:05:57
    2016-05-22 - 2016-05-29 0:00:20 - 65:33:41 33:12:08
    2016-05-29 - 2016-06-05 - - 58:08:51 109:48:11
    2016-06-05 - 2016-06-12 0:00:05 0:00:11 83:02:25 84:51:09
    2016-06-12 - 2016-06-19 0:00:03 0:00:05 65:35:14 102:17:24
    2016-06-19 - 2016-06-26 - - 70:42:01 97:14:46
    2016-06-26 - 2016-07-03 0:12:41 0:00:15 50:14:35 32:05:34
    2016-07-03 - 2016-07-10 0:08:11 4:01:11 17:48:32 99:21:06
    2016-07-10 - 2016-07-17 0:00:02 - 14:53:27 152:57:13
    2016-07-18 - - - 23:59:36
    2016-07-19 0:00:07 0:00:10 0:01:16 16:06:23
    2016-07-20 - - 2:32:47 8:06:13
    2016-07-21 - - 4:47:30 19:01:20
    2016-07-22 - - 3:50:59 14:40:59
    2016-07-23 - - 2:51:16 21:08:23
    2016-07-24 - - 17:24:40 1:02:06
    Battery capacity history
    Charge capacity history of the system's batteries
    2015-12-27 - 2016-01-03 41,276 mWh 42,157 mWh
    2016-01-03 - 2016-01-10 41,276 mWh 42,157 mWh
    2016-01-10 - 2016-01-17 41,482 mWh 42,157 mWh
    2016-01-17 - 2016-01-24 41,101 mWh 42,157 mWh
    2016-01-24 - 2016-01-31 40,151 mWh 42,157 mWh
    2016-01-31 - 2016-02-07 41,135 mWh 42,157 mWh
    2016-02-07 - 2016-02-14 40,656 mWh 42,157 mWh
    2016-02-14 - 2016-02-21 40,775 mWh 42,157 mWh
    2016-02-21 - 2016-02-28 40,770 mWh 42,157 mWh
    2016-02-28 - 2016-03-06 40,640 mWh 42,157 mWh
    2016-03-06 - 2016-03-13 40,962 mWh 42,157 mWh
    2016-03-13 - 2016-03-20 42,556 mWh 42,157 mWh
    2016-03-20 - 2016-03-27 42,583 mWh 42,157 mWh
    2016-03-27 - 2016-04-03 42,574 mWh 42,157 mWh
    2016-04-03 - 2016-04-10 42,576 mWh 42,157 mWh
    2016-04-10 - 2016-04-17 40,448 mWh 42,157 mWh
    2016-04-17 - 2016-04-24 38,357 mWh 42,157 mWh
    2016-04-24 - 2016-05-06 33,457 mWh 42,157 mWh
    2016-05-06 - 2016-05-08 31,583 mWh 42,157 mWh
    2016-05-08 - 2016-05-15 30,911 mWh 42,157 mWh
    2016-05-15 - 2016-05-22 28,105 mWh 42,157 mWh
    2016-05-22 - 2016-05-29 26,152 mWh 42,157 mWh
    2016-05-29 - 2016-06-05 26,152 mWh 42,157 mWh
    2016-06-05 - 2016-06-12 17,147 mWh 42,157 mWh
    2016-06-12 - 2016-06-19 10,943 mWh 42,157 mWh
    2016-06-19 - 2016-06-26 9,188 mWh 42,157 mWh
    2016-06-26 - 2016-07-03 9,188 mWh 42,157 mWh
    2016-07-03 - 2016-07-10 4,155 mWh 42,157 mWh
    2016-07-10 - 2016-07-17 2,174 mWh 42,157 mWh
    2016-07-18 2,174 mWh 42,157 mWh
    2016-07-19 2,174 mWh 42,157 mWh
    2016-07-20 2,174 mWh 42,157 mWh
    2016-07-21 2,174 mWh 42,157 mWh
    2016-07-22 424 mWh 42,157 mWh
    2016-07-23 144 mWh 42,157 mWh
    2016-07-24 144 mWh 42,157 mWh
    Battery life estimates
    Battery life estimates based on observed drains
    2015-12-27 - 2016-01-03 3:51:16 3109:39:29<br><br>1 % / 16 h 3:56:12 3176:01:51<br><br>1 % / 16 h
    2016-01-03 - 2016-01-10 4:38:00 371:54:57<br><br>4 % / 16 h 4:43:56 379:51:15<br><br>4 % / 16 h
    2016-01-10 - 2016-01-17 3:58:37 278:58:58<br><br>6 % / 16 h 4:02:30 283:31:21<br><br>6 % / 16 h
    2016-01-17 - 2016-01-24 7:04:47 29:54:31<br><br>53 % / 16 h 7:15:42 30:40:38<br><br>52 % / 16 h
    2016-01-24 - 2016-01-31 3:42:28 91:23:38<br><br>18 % / 16 h 3:53:34 95:57:36<br><br>17 % / 16 h
    2016-01-31 - 2016-02-07 4:02:25 264:41:24<br><br>6 % / 16 h 4:08:26 271:15:58<br><br>6 % / 16 h
    2016-02-07 - 2016-02-14 6:45:57 196:25:54<br><br>8 % / 16 h 7:00:57 203:41:02<br><br>8 % / 16 h
    2016-02-14 - 2016-02-21 3:07:09 158:29:38<br><br>10 % / 16 h 3:13:29 163:51:57<br><br>10 % / 16 h
    2016-02-21 - 2016-02-28 3:18:12 70:09:27<br><br>23 % / 16 h 3:24:57 72:32:39<br><br>22 % / 16 h
    2016-02-28 - 2016-03-06 - - - -
    2016-03-06 - 2016-03-13 5:55:19 149:54:18<br><br>11 % / 16 h 6:05:41 154:16:41<br><br>10 % / 16 h
    2016-03-13 - 2016-03-20 - - - -
    2016-03-20 - 2016-03-27 - - - -
    2016-03-27 - 2016-04-03 3:57:39 - 3:55:20 -
    2016-04-03 - 2016-04-10 4:07:18 152:32:15<br><br>10 % / 16 h 4:04:52 151:02:11<br><br>11 % / 16 h
    2016-04-10 - 2016-04-17 - - - -
    2016-04-17 - 2016-04-24 3:15:38 19:05:50<br><br>84 % / 16 h 3:35:01 20:59:21<br><br>76 % / 16 h
    2016-04-24 - 2016-05-06 35:37:31 84:54:03<br><br>19 % / 16 h 44:53:21 106:58:41<br><br>15 % / 16 h
    2016-05-06 - 2016-05-08 - - - -
    2016-05-08 - 2016-05-15 - - - -
    2016-05-15 - 2016-05-22 - - - -
    2016-05-22 - 2016-05-29 - - - -
    2016-05-29 - 2016-06-05 - - - -
    2016-06-05 - 2016-06-12 - - - -
    2016-06-12 - 2016-06-19 - - - -
    2016-06-19 - 2016-06-26 - - - -
    2016-06-26 - 2016-07-03 0:18:23 2:33:08<br><br>627 % / 16 h 1:24:20 11:42:37<br><br>137 % / 16 h
    2016-07-03 - 2016-07-10 0:17:16 6:38:08<br><br>241 % / 16 h 2:55:12 67:19:33<br><br>24 % / 16 h
    2016-07-10 - 2016-07-17 0:00:35 - 0:11:31 -
    2016-07-18 - - - -
    2016-07-19 0:00:49 0:00:35<br><br>164571 % / 16 h 0:16:07 0:11:33<br><br>8312 % / 16 h
    2016-07-20 - - - -
    2016-07-21 - - - -
    2016-07-22 - - - -
    2016-07-23 - - - -
    2016-07-24 - - - -
    Current estimate of battery life based on all observed drains since OS install
    Since OS install 0:00:50 0:26:12<br><br>3664 % / 16 h 4:07:40 127:51:33<br><br>13 % / 16 h
    2016-07-25T13:32:52+00:00
    I have been experiencing this same issue now for a month or two.  At this point I cannot be off of power for longer than 15 minutes.. will go from full charge to dead.
    Battery Name: x898289
    Battery Manufacturer: SIMPLO
    Serial Number: 1165761028
    Full Charged Capacity: 144mWh
    Discharge Cycles: 105
    This is unacceptable for 1 year old hardware.  Microsoft needs to immediately acknowledge this issue and provide a fix. Has anyone heard any rumblings of a Class Action Lawsuit around this situation yet?  I refuse to pay 50% of what the hardware costs 1 year later to repair the battery.
