2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-25T06:09:35+00:00
    If you guys look at everyone's charts, it seems to be a problem in 2016. The past years in those charts seem fine, but if you look at 2016, there's a huge degrade. I'll safely assume it's due to Windows 10 or the firmware updates.
    Also, it like it not a thing for the SP4.
    Note: I don't own a Surface at the moment but i'm for sure getting a SP4 later this week.
    I doubt that. My SP3 is 9 months old, have Win10 from day 1, no degradation of the SIMPLO battery. I think it is tied to the amount of time used, not the OS itself.
    Anyways, the OS cannot kill the battery itself, only do a high battery utilization, but I am getting good usage times.
    2016-07-25T05:45:17+00:00
    2016-07-24T20:56:21+00:00
    Adding this information to my post and replies.
    Definitely: Microsoft, we have an issue.
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1165367812
    CHEMISTRY LION
    DESIGN CAPACITY 42 mWh
    FULL CHARGE CAPACITY 3 mWh
    CYCLE COUNT 609
    Battery capacity history
    Charge capacity history of the system's batteries
    2015-11-22 - 2015-11-29 40 mWh 42 mWh
    2016-03-21 - 2016-03-27 42 mWh 42 mWh
    2016-03-27 - 2016-04-03 42 mWh 42 mWh
    2016-04-03 - 2016-04-10 41 mWh 42 mWh
    2016-04-10 - 2016-04-17 35 mWh 42 mWh
    2016-04-17 - 2016-04-24 31 mWh 42 mWh
    2016-04-24 - 2016-05-01 30 mWh 42 mWh
    2016-05-01 - 2016-05-08 29 mWh 42 mWh
    2016-05-08 - 2016-05-15 24 mWh 42 mWh
    2016-05-15 - 2016-05-22 22 mWh 42 mWh
    2016-05-22 - 2016-05-29 16 mWh 42 mWh
    2016-05-29 - 2016-06-05 18 mWh 42 mWh
    2016-06-05 - 2016-06-12 22 mWh 42 mWh
    2016-06-12 - 2016-06-19 22 mWh 42 mWh
    2016-06-19 - 2016-06-26 19 mWh 42 mWh
    2016-06-26 - 2016-07-03 15 mWh 42 mWh
    2016-07-03 - 2016-07-10 10 mWh 42 mWh
    2016-07-11 8 mWh 42 mWh
    2016-07-12 8 mWh 42 mWh
    2016-07-13 7 mWh 42 mWh
    2016-07-14 7 mWh 42 mWh
    2016-07-15 6 mWh 42 mWh
    2016-07-16 6 mWh 42 mWh
    2016-07-17 6 mWh 42 mWh
    2016-07-18 6 mWh 42 mWh
    2016-07-19 5 mWh 42 mWh
    2016-07-20 5 mWh 42 mWh
    2016-07-21 4 mWh 42 mWh
    2016-07-22 4 mWh 42 mWh
    2016-07-23 4 mWh 42 mWh
    2016-07-24T19:30:09+00:00
    Same story, same graph. About a month ago, a steady decline, cant unplug the tablet or it instantly dies. SIMPLO battery inside. The deal is, most people buy these to last at least 3 years pushing 5 on most high end equipment. And I got the maxed out version, all stops pulled.
    If it is not a firmware issue, there should be a mail-in replacement program with extended warranty, or a lot of professionals will cross Microsoft off the list, and switch to Apple. Not kidding. The repair offer at any cost is a slap in the face to those that invested in the product.
    As an example, HP recalled a massive amount of zd7000 laptops due to failed graphics chip, all expenses paid. So did Sony with their laptops. Microsoft best take example there if they want to save face at all.
    What future device can they advertise for us to buy next, if their tablet becomes a desktop in one years time?
    Microsoft is no small fish, they should claim responsibility before a class action lawsuit.
    Mine just became 'true' desktop replacement, literally.
    Sad Panda...
