2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-24T16:06:29+00:00
    I have my Surface Pro 3 Windows 10 now just over 18 months and have the issue where my battery lasts only 15 minutes after a full charge.
    Have been trying many options, starting with the default power settings, then lower energy consumptions but nothing improved.  Other Surface Pro 3 computers, older then the one I use last over 2 hours.
    With this issue, the "tablet" can only be used as a desktop, always plugged in.
    Is there something else that could be checked to improve battery at least 8 fold?
    When originally purchased, we expected the system, would last comfortably at least 3+ years.
    Thank you.
    2016-07-24T15:12:25+00:00
    While my battery wear is at 10%, it discharges weirdly fast and takes forever to charge. Luckily, I had called Microsoft in June about this issue and then they had said that replacing the driver would help which it didn't.
    Called them up today and explained how I had called regarding this same issue when it was in warranty and they have agreed to replace it free of charge as a I warranty replacement. I hope they don't send out the refurbished product which has a simplo battery as well. fingers crossed.
    2016-07-24T03:20:58+00:00
    I don't use my surface pro 3 that often but suddenly I notice that my battery have degraded up to 30%. I have an LG battery not a SIMPLO. For the past year the battery wear was between 0 and 3% now is almost 30%. Looks like is not only a SIMPLO issue. Yesterday was 25% wear now is almost 30% looks like is going to get worst and worst. Too bad because if I want to replace the battery they will give me a prob. refurb one. I took good care of my surface pro 3...does not have any scratches and have the expensive screen protector and I will loose that.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=2ca3c7d6-7870-46bc-95c8-5b48446004a9)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=f867826f-18f3-4d50-983b-0fa0c0658a2d)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=45c43713-6b20-41f0-a6ea-793c42cc89ff)
    2016-07-24T03:12:52+00:00
    an alternative explanation would be that my battery degraded by 2% during the session before I restarted the machine.
    That's exactly what I was thinking, and what I feared before even hearing about this whole Simplo kerfuffle
