2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-24T03:08:54+00:00
    an alternative explanation would be that my battery degraded by 2% during the session before I restarted the machine.
    2016-07-24T02:55:30+00:00
    charging stopped at 98%
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=0fd8209f-e09c-410e-b080-99e09e2bd699)
    unplugged and restarted surface, now it reports 100%! How could it be?
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=71e5e8cc-a246-4e6d-9454-c831096fffe6)
    I really do hope it is a software or firmware issue...could it be that the battery is never fully charged (stops at 98%) but when the next time the computer starts it thinks it is fully charged and treat the 98% as 100%. So the capacity will appear to drops at a rate of 0.98 ^ n or 0.95 ^ n if charging stops at 95%.
    I noticed this myself. Just the other day my SP3 stopped charging at 95%. After restarting it, the battery meter claimed it was now 100%
    2016-07-24T02:47:53+00:00
    2016-07-23T17:13:56+00:00
    I doubt it works this way. MS already know that a significant portion of their userbase has this problem. The right thing to do would be for them to identify the faulty batch and issue a recall.
    Either MS will screw up and ignore this, or fix it for everyone, don't worry. I am pretty sure it would be the latter.
