2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-23T16:53:30+00:00
    I'd like to know this as well.
    2016-07-23T15:57:30+00:00
    How can I get my name into Microsoft that I have the SIMPLO battery issue without paying the $99 to talk to them?
    2016-07-23T10:25:46+00:00
    I think yours is a one-off failure. Please contact support
    https://www.microsoft.com/surface/en-us/support/contact-us - if you are in the
    US, go to the closest physical retail Microsoft Store.
    (this is the only report of a SP4 I've seen).
    Barb
    MVP-Windows and Devices for IT
    2016-07-23T10:24:37+00:00
    Right now this looks like a "one off" (I hope).
    >>That's from a Surface Pro 4 right? Looks like DYN has the same issue as SIMPLO.
    Barb
