2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-23T10:22:03+00:00
    don't worry about this. Engineering knows these are two separate issues and
    there are different groups involved. if someone wants to start a new thread,
    fine. Engineering DOES want to look at the Code 45 thing. They think it may be a
    WU issue and have suggested trying the MSI file (supposedly available this
    coming Monday) to see if that clears the Code 45 issue. Me, I'm not so sure it
    will.
    I don't have the time to try to split out the Code 45 posts from this thread,
    but since Microsoft clearly understands the difference and wants to pursue
    both... and yes, everyone knows that the battery drain/failure is the important
    big issue.
    >>Please start a new topic for this issue as I believe it is distracting us from the main focus which is SIMPLO batteries failing.  Since the code 45 affects both SIMPLO and LGC this is not a cause for the batteries draining.
    Barb
    MVP-Windows and Devices for IT
    2016-07-23T08:55:20+00:00
    What I'm looking for in particular is where the firmware update leaves you with error codes.  The lack of battery life is a separate issue that we all want to fight for, but for now I just need folks with the slightly mangled update experience.
    I understand you are here to help, which I very much appreciate, but I don't want us to get off topic. I was curious about that error in case it was related to the battery issue but clearly it isn't from what people are reporting.
    2016-07-23T07:44:34+00:00
    I am at home these days, so not much discharging, but I was travelling extensively in March and June and used the SP3 on battery at airports and planes a lot with high CPU (I process photos I have taken during my trip on the plane), discharging to 0 multiple times.
    I think there's a time factor, too.
    2016-07-23T07:30:37+00:00
    Yes, this is a SP4 with DYN battery. Might be just an unhappy coincidence with my SP4, but looking at all the reports this issue began around the same time. This makes me really wonder what is going on here.
