2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-23T07:14:30+00:00
    That's from a Surface Pro 4 right? Looks like DYN has the same issue as SIMPLO.
    2016-07-23T07:12:35+00:00
    The battery capacity drops quicker the more it's discharged. Looking at that report it looks like you are mostly on AC power but if you look at the period early on where it's on battery the capacity drops.
    I'm not saying you should do this but I bet if you started using the battery more, letting it discharge down to about 50% or less, you'd see it degrade faster.
    2016-07-23T06:55:55+00:00
    Installed batteries
    Information about each currently installed battery
    NAME X910528
    MANUFACTURER DYN
    SERIAL NUMBER 42339
    CHEMISTRY LION
    DESIGN CAPACITY 38 mWh
    FULL CHARGE CAPACITY 30 mWh
    CYCLE COUNT 172
    2016-07-23T05:50:37+00:00
    I have the Simplo battery too, at a cycle count of 139, with hardly any degradation, but my SP3 is only about 9 months old now. I hope they fix or recall the devices before my warranty runs out.
    Installed batteries
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER XXXXXXXXXXX
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 41,184 mWh
    CYCLE COUNT 139
    Recent usage
    Power states over the last 3 days
    2016-07-20 19:03:56 Connected standby Battery 100 % 41,276 mWh
    19:03:56 Active Battery 100 % 41,276 mWh
    19:36:45 Connected standby Battery 76 % 31,555 mWh
    19:42:20 Active Battery 75 % 31,145 mWh
    19:43:51 Connected standby Battery 75 % 30,757 mWh
    19:54:08 Active Battery 73 % 30,005 mWh
    20:09:16 Active AC 63 % 25,840 mWh
    20:16:24 Active Battery 63 % 25,802 mWh
    20:47:02 Connected standby Battery 38 % 15,595 mWh
    20:47:03 Suspended 38 % 15,595 mWh
    2016-07-21 08:26:15 Connected standby Battery 100 % 41,192 mWh
    08:26:15 Suspended 100 % 41,192 mWh
    08:26:50 Connected standby AC 100 % 41,192 mWh
    08:26:50 Active AC 100 % 41,192 mWh
    08:34:39 Active Battery 100 % 41,192 mWh
    08:34:39 Connected standby Battery 100 % 41,192 mWh
    08:34:39 Suspended 100 % 41,192 mWh
    23:48:06 Connected standby AC 100 % 41,192 mWh
    23:48:06 Active AC 100 % 41,192 mWh
    23:52:56 Connected standby AC 100 % 41,192 mWh
    23:52:56 Suspended 100 % 41,192 mWh
    2016-07-22 20:20:31 Connected standby AC 100 % 41,192 mWh
    20:20:31 Active AC 100 % 41,192 mWh
    20:22:24 Connected standby AC 100 % 41,192 mWh
    20:22:25 Suspended 100 % 41,192 mWh
    21:58:50 Connected standby AC 100 % 41,192 mWh
    21:58:50 Active AC 100 % 41,192 mWh
    22:15:00 Suspended 100 % 41,192 mWh
    22:21:27 Active AC 100 % 41,192 mWh
    22:22:28 Connected standby AC 94 % 38,874 mWh
    22:38:08 Active AC 98 % 40,295 mWh
    22:38:34 Connected standby AC 98 % 40,318 mWh
    22:38:35 Suspended 98 % 40,318 mWh
    2016-07-23 09:45:19 Active AC 100 % 41,184 mWh
    10:12:27 Connected standby AC 100 % 41,184 mWh
    10:13:13 Active AC 100 % 41,184 mWh
    10:13:14 Connected standby AC 100 % 41,184 mWh
    10:19:43 Suspended 100 % 41,184 mWh
    10:44:15 Active AC 100 % 41,184 mWh
    10:44:15 Suspended 100 % 41,184 mWh
    10:46:17 Active AC 100 % 41,184 mWh
    10:46:17 Suspended 100 % 41,184 mWh
    10:48:28 Active AC 100 % 41,184 mWh
    10:48:28 Suspended 100 % 41,184 mWh
    10:52:37 Active AC 100 % 41,184 mWh
    10:53:41 Connected standby AC 100 % 41,184 mWh
    10:55:42 Active AC 100 % 41,184 mWh
    10:59:45 Connected standby AC 100 % 41,184 mWh
    10:59:46 Suspended 100 % 41,184 mWh
    11:13:00 Connected standby AC 100 % 41,184 mWh
    11:13:00 Active AC 100 % 41,184 mWh
    11:13:00 Report generated AC 100 % 41,184 mWh
