2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-23T02:27:54+00:00
    This evening I ran the battery down until I got the battery symbol when powering on (the one that appears before the Surface logo). I then plugged in using the supplied charger and powered on holding down Volume up to go into the UEFI bios screen & then left it charging.
    After over 6 hours later I turned it off and on then let Windows start up. Battery shows 100% charged but capacity has dropped again. I think running these batteries down is a bad idea, as each time the capacity drops, and I'm left feeling that this isn't a firmware/driver issue after all.
    How much longer can Microsoft carry on ignoring this?
    2016-07-23T02:19:04+00:00
    Surface Pro 4 too!
    Does your SP4 have a SIMPLO battery? Please post your battery report. Would help get us noticed if this goes beyond SP3 devices.
    2016-07-23T00:12:58+00:00
    2016-07-23T00:11:03+00:00
    This really blows - the SP3 i bought was an i7 with a quarter TB storage, a nearly $2000 investment, and now it only functions as a desktop. Really dissapointed in Microsoft and I cant see myself recommending these devices to anyone at this point. At the very least, Microsoft should post some explanation and provide affected users with some piece of mind that they are at least looking into it on their site or something. Our ancient iPad 2 from 2011 still runs more than 6 hours a day. BOOOOOO
