2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-23T00:03:12+00:00
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=c9ab62dd-2ab1-444a-85ae-062481f9a9a1)![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=e6286f96-bf20-4f0d-8452-c52bda54e252)![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=065acbf2-4337-49e5-9124-fdfc1fa85667)
    This certainly is not an isolated case!
    Never left the thing on charger when turned off. >300 cycles in 1.5 year that's a healthy count.
    Tried the tips described in the other post by using the battery to 50% and charge it up. The degradation accelerated!
    It's NOT all about $450 (which they shouldn't charge). This is about business practice and justice!
    Battery does not charge, Microsoft does! How ironic!
    2016-07-22T23:41:30+00:00
    2016-07-22T23:29:37+00:00
    What I'm looking for in particular is where the firmware update leaves you with error codes.  The lack of battery life is a separate issue that we all want to fight for, but for now I just need folks with the slightly mangled update experience.
    2016-07-22T22:47:30+00:00
    Surface Pro 4 too!
    This seems to be a major issue with Windows 10:
    2016-06-27 - 2016-07-04 35 mWh 38 mWh
    2016-07-04 - 2016-07-11 34 mWh 38 mWh
    2016-07-12 34 mWh 38 mWh
    2016-07-13 34 mWh 38 mWh
    2016-07-14 33 mWh 38 mWh
    2016-07-15 33 mWh 38 mWh
    2016-07-16 33 mWh 38 mWh
    2016-07-17 32 mWh 38 mWh
    2016-07-18 33 mWh 38 mWh
    2016-07-19 32 mWh 38 mWh
    2016-07-20 31 mWh 38 mWh
    2016-07-21 30 mWh 38 mWh
    2016-07-22 30 mWh 38 mWh
    It started all around April.
    So this is not just SP3 related!
    Cheers
    SJ
