2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-22T22:47:26+00:00
    Count me in!
    2016-07-22T22:40:50+00:00
    I did the update this morning as well and I will say that mine does seem a bit better. I also followed the other instructions posted here about running the battery down every day and it seems to be helping.
    Before the update, when I was at 100% the most I would see is just over remaining. Today I updated and the battery was at 80% and it said I have 4 hrs 6 min remaining.
    2016-07-22T22:40:25+00:00
    I noticed that, too, going through the postings. Seems like the significant drops started March, April, and May for most people. And then the batteries plummeted down from there. Weird.
    2016-07-22T22:30:32+00:00
    I believe it is time for us all to consider a class action lawsuit about battery degradation. Spending any monies to replace something MS knew or should have known was defective is unfair to consumers.
    They should offer us a replacement battery at cost.
    ******@gmail.com
