2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-26T02:55:47+00:00
    Here's mine:
     ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=2277f58b-1ad2-425d-800e-63b25a409871)
    Serial number is removed because I have been posting this pic in a lot of other places too.
    But this is just not right.  This device is supposed to be portable but mine will not work unless it is plugged into the wall at this point.  The second power is removed it will shut off.  A surface is almost pointless if it is not portable.
    I paid a lot of money for this device because I thought it was built with quality and customer service in mind, but it is clear neither of those are true.  There is no way I would have bought this thing if I knew the battery would be completely dead in less than two years (and only 5 months out of warranty).  And if I knew back then and had the option, I would have made sure it did not have the SIMPLO battery in it.
    This is clearly a defect from the factory.  I really hope that Microsoft does the right thing with this one.
    2016-07-26T02:49:03+00:00
    Honestly my usage was fine for a year, even with Windows 10.  The system ran fine.. then over the period of about a month battery life plummeted... to the point now that the device doesn't work unless on AC power.
    I am beyond frustrated with Microsoft's lack of communication on this.
    2016-07-26T02:19:21+00:00
    I'll add my  surface to the pool of bad batteries as well. I write this from my "fully charged" SP3 which has been on for 10 minutes. I now have 69% battery left, and it estimates my remaining time at 20 minutes. Let's hope MS can do something about this, as I have been nothing but happy with the functionality of this excellent machine overall. But this is just ridiculous.
    Here is my battery capacity report:
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=754d66e8-7e1c-48e1-b0e1-97f38315950b)
    2016-07-26T00:38:52+00:00
    I'll add my voice as well.  Just recently started seeing rapid discharge of battery.  I ran the battery command, and sure enough I have the simplo battery as well.  I find it unacceptable that Microsoft would charge to fix a massive battery issue they are facing.  I hope that they will rectify this shortly, as now I will not be encouraging others to purchase a Microsoft product.
    I've already gone to Amazon and rewrote my review on the MS Surface Pro 3 telling people NOT TO BUY THEM due to this battery issues and MS's inability to respond to this issue. They've had plenty of time to address this. Time to start spreading the news!
    Couldn't agree more. This thread is well over two months old, time to start tightening the screws. I've put up with enough BS from a $1000+ tablet, whether it be a curving body, yellowing screen stripe, or stylus jitters, and I've been pleasant about it. Enough is enough.
