2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-22T15:25:44+00:00
    Here are the new firmware update detail:
    Surface Pro System Aggregator Firmware
    • v3.9.850.0 increases battery life during sleep mode and improves keyboard stability.
    Surface Pro UEFI
    • v3.11.1450.0 improves system sleep and hibernation behavior when battery level is low.
    Surface Fingerprint Sensor
    • v2.2.10.8 increases finger print touch stability coming out of sleep.
    Surface Pen Settings
    • v11.0.311.0 enhances pen setting driver stability.
    https://www.microsoft.com/surface/en-us/support/install-update-activate/pro-3-update-history?os=windows-10&=undefined
    2016-07-22T13:36:58+00:00
    mine (LGC battery) looks like this with a Code 45.
    >>Does everyone have similar items shown in Device Manager under Batteries (you need to open the View menu and select "Show hidden devices").  The middle device below wasn't showing correctly (showed as "Unknown device") until I removed it and then checked for updates.  This is after installing the firmware released overnight.
    Barb
    MVP-Windows and Devices for IT
    Mine SIMPLO but give same Code 45.
    2016-07-22T12:59:51+00:00
    2016-07-22T11:59:34+00:00
    That is interesting.  I can't wait for those release notes to go up so we know exactly what was in the update today.
