2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-22T11:36:11+00:00
    mine (LGC battery) looks like this with a Code 45.
    >>Does everyone have similar items shown in Device Manager under Batteries (you need to open the View menu and select "Show hidden devices").  The middle device below wasn't showing correctly (showed as "Unknown device") until I removed it and then checked for updates.  This is after installing the firmware released overnight.
    Barb
    MVP-Windows and Devices for IT
    2016-07-22T11:33:15+00:00
    Hi Robert, I noticed many people have started having this problem in March and April. I wonder if it's cause by the firmware update in January that relates to the battery driver (
    • Microsoft Surface ACPI-Compliant Control Method Battery driver update (v1.2.0.2) ensures correct surface driver is installed.)
    Maybe your hasn't been updated....just guessing out loud?
    How to check firmware updates
    http://www.tenforums.com/tutorials/5472-windows-update-history-view-windows-10-a.html
    Firmware updates
    2016-07-22T10:59:30+00:00
    Microsoft told the press that folks won't be charged $99 for this battery issue.
    Dispute the charge with your credit card company.
    Barb
    2016-07-22T10:51:14+00:00
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=03525fd7-6a7e-4be2-b11c-4b020d105d17)
