2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-22T10:11:10+00:00
    Adding to juanmaq's observation, about a month ago I was able to get my Surface to last more than the estimated hours, as in it could last about ~3 hours despite the full charge capacity was around ~700 mWh at 80% charged. That was after I leave my Surface Pro unplugged for few weeks while I'm out of the country. I saw this behavior only once, and after that it start going back to the "normal" behavior. I've been trying to reproduce it, but no luck so far. I think and juanmaq's experience might suggest that this is more of a battery firmware's problem than a permanent damage (hopefully).
    Still, I really wish someone from Microsoft would at least come here and say "we're looking into it." They way they keep quiet about the problem only make sure everyone who is affected will never buy their products again. Which is a shame, because Surface hardware is quite nice.
    2016-07-22T09:14:19+00:00
    Just adding another voice; another SIMPLO battery whose capacity has fallen off a cliff about a year into warranty. It maintained near peak until about 11 months. By 14 months, it was down to about 25% and is now (15 months) at about 8% (~3,450 mWh). The reality is rather worse than this suggests however, since below about 40%, the surface can just shut down at any time.
    NAME                                 X898289
    MANUFACTURER               SIMPLO
    DESIGN CAPACITY             14,156 mWh
    FULL CHARGE CAPACITY   3,443 mWh
    CYCLE COUNT                    196
    I don't have the time or patience to sit on tech support getting told to turn the computer on and off and check spurious and unrelated things in System. I just hope enough voices here will pull Microsoft out of the 'head in the sand' reaction, although if the arc touch mouse problems are anything to go by, I doubt it.
    2016-07-22T08:14:48+00:00
    there is a firmware update for the Surface Pro 3, anybody see any difference after applying it?
    Nothing so far and mine has still stopped charging at 95% -- waiting for release notes to be updated here:
    Surface Pro 3 update history
    2016-07-22T08:07:23+00:00
