2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-22T07:31:25+00:00
    I posted my battery results earlier.  When I go to try and contact Microsoft about the problem they say it will cost $99 for them to talk about my SP3.
    So Microsoft have requested people contact support so that they can gather more information and then they put a barrier of $99 to prevent us from doing so.  That is disgraceful.
    I've been going through all the Surface Pro 3 battery related items in the Feedback Hub directing people to this topic so that they can post their battery reports.
    I also noticed today that there is new firmware dated 21/07 (or 07/21 for those in the US) but so far the support page hasn't been updated: https://www.microsoft.com/surface/en-gb/support/install-update-activate/pro-3-update-history?os=windows-10&=undefined
    After installing it the battery driver hasn't changed & my SP3 still stops charging at 95%.
    2016-07-22T02:54:20+00:00
    I have a SIMPLO X904849 with a little over 100 cycles on it and the problem is starting for me. My Surface Complete ends in about 2 months : /
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=980c94ef-9a6a-4b5b-99a6-b27c2d904814)
    Today it was 41,830 full charge capacity. It is slowly creeping down. While its not as bad as some of the others, I am worried that this could be a long term problem for me and something needs to be done about this.
    2016-07-21T23:35:04+00:00
    I think it might be starting for me too D: for some reason the capacity history isn't appearing on my batteryreport but earlier today I had to do some tinkering with system files to fix Windows Update so that might be why
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=87611560-d501-428f-bcb0-232a6ef479e3)
    2016-07-21T22:54:45+00:00
    About four months ago, I began to notice some battery deterioration.  Now I'm down to about 3,000 mWh capacity.  Of course, the bulk of the deterioration occurred right as the warranty expired.  This feels scummy to me.  I sincerely hope that Microsoft will do something to attempt to make this right beyond telling me that I need to spend twice the amount the head of the Surface team said I would have to spend to replace the battery.
    If something isn't done to make this right, I'll just have to cut my losses and never purchase hardware from Microsoft again.  It's truly unfortunate that this has happened as I really enjoy my Surface Pro 3 until this happened.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=4943729d-b03d-4f4e-87ee-489d70be1075)
