2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-22T18:40:48+00:00
    I keep everything up to date. My history isn't filled out because I have recently refreshed Windows (made sure update installed too). It's really odd that this is happening now. I don't recall seeing much battery degradation over the past few months, but from what little data I have, there is definitely a downward trend that's happening faster than it should.
    I'm going to make another partition and do a new install of windows to see if it reads the same as my primary partition.
    2016-07-22T18:40:16+00:00
    I believe these two address the batter but will have to wait and see.
    Surface Pro System Aggregator Firmware
    • v3.9.850.0 increases battery life during sleep mode and improves keyboard stability.
    Surface Pro UEFI
    • v3.11.1450.0 improves system sleep and hibernation behavior when battery level is low.
    2016-07-22T15:45:15+00:00
    Hello everyone,
    I just to continue spreading the word about recent battery problems with Surface Pro 3 with SIMPLO batteries.
    Mine is 13 months old, and battery last 1 hour; this is outrageous. On top of that, I called Microsoft support and they asked me to pay 560$ to replace the battery. This has become a big issues for a lot of users and they simply ignore the fact ask for out of warranty charges.
    It is sad and frustrating to see how Microsoft ignores that they caused this problem with their supplier it is us who need to pay for it.
    We spent our 1,800$ that became useless in less that 2 years.
    2016-07-22T15:37:46+00:00
    So nothing that directly addresses the reduced battery capacity then. Still silence from the Surface team.
